Question about Bissell Vacuums
A friend used my Bissell Proheat Clearview shampooer, and didn't wash out the shamppoo bottle nor turn the dial to water only after using. The flow assembly on the bottle was destroyed. I bought a new bottle but still can't get the shampoo to flow. Hope you can help.
    President:
  • 1,952 Answers
Pls model no
Posted on Oct 12, 2008
  • mohammed marika thambi
    mohammed marika thambi Oct 12, 2008
    The spray hoses are bocked. The only way to clean them is to take the
    clear plastic cover off, un screw the base, lift cover, pull out red
    spray nosels, disconnect from main hose and wash under tap. Takes ages
    to do and is very fiddly.
    Design fault as grit gets into spray holes.
    Make sure you always clean machine after use,
    check for pluged hose at heater in lower part of handle. flush system with hot water after using
    The bottom part (for the floor) it dont work but its the belt Im
    already fixing that. The tools used to work but I tried to clean
    yesterday and the hose will **** up water if you throw the water on the
    floor but it wont spray any out. Any help would be greatly appreciated
    thanks for fixya.
    Genius:
  • 3,422 Answers
If your floor cleaner doesn't spray, chances are the heater unit is clogged.
The heater unit is located inside the body of the machine, behind the power/heater switches. Remove 6 screws and split the case open. The silver metal "box" inside is the heater unit. Take note of how the hoses and wires are connected. Better yet, take a digital photo for reference.
Remove the wires and hoses. Take the box to a work bench, and unscrew the 6 or 7 screws that hold on the lid. Don't lose the red washers that are found on the inside of the box that keep water from leaking out of the screw holes You'll see a "maze" where the water runs around to get heated up. Clear this of all debris. The inlet and/or outlet ports may also be clogged. I used an appropriate sized drill bit mounted on an electric screwdriver to carefully "drill" out the clogs. Make sure all the debris has been removed. I used an electric screwdriver because my 18v DeWalt hammer drill would have been overkill Reassemble to box -Rewire and plumb the box according to your notes or reference photo. Put the machine back together.
  • Priya darshan Oct 12, 2008
    Source-Fixya's hotsam
    Sergeant:
    Champion:
  • 435 Answers
Hi, Could you please provide us the model # ?
Thanks,
    Brigadier General:
  • 6,966 Answers
A similar concern has been addressed on this site. With your indulgence, pls click here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to use bissell proheat clearview plus
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 07, 2010 | Bissell 7901-R Clearview Proheat Plus...
My Bissell Proheat Clearview is not spraying water nor taking
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrthrw
Apr 25, 2010 | Bissell 1699 ProHeat Clear View Upright...
Can't get any water to flow through my bissell proheat rug shampooer
heatman101
tuitu
Sep 28, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
How to use bissell proheat clearview 12 amps rug
Here is a user guide, and it will show you how to use it. just click and read. its a PDF file. you might need adobe to look at it. It is a free download.
http://www.bissell.com/images/UserGuides/7901_1008.pdf
Hope this helps you from sawdust
Aug 12, 2009 | Bissell Vacuums
Have a bissil proheat clearview plus model 1699-1,there is no water flow. soap seems to work. It was used one time but the system was not flushed. Has not worked since.
if you have spray through your hose and no spray on your carpet then your heater will be clogged with soap. try this and post later if thats not it.
Sep 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Jun 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
My bissell powersteamer clearview will not **** up water
Check the heater inside of the handle, it may be clogged and not allowing water to flow. The hose doesn't use the heater and that would be why it flows out the hose.
Apr 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
71 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
