Question about Olympus Cameras
I cant get an external flash to work. - Olympus Cameras
I had to change the settings and went into manual mode
Posted on Oct 12, 2008
Screen flashing on external monitor
The monitor maybe faulty, try the monitor on another computer/laptop, then if it still flashes then then monitor is faulty.
Feb 20, 2013 | Computers & Internet
Flash not working; used to work; done resets
sounds like a bad capacitor.... it cant store the energy to make a burst.... you could test by going to a camera store and see if a external flash will work on the hot shoe.. if it does it will most likely be cheaper just to buy that than fix the on camera flash.. and it would be a much better and more powerful flash as well
Nov 11, 2012 | Nikon D3000 D3100 18-55mm
Cant connect phone through usb on 1525 dell?? wont read anything when i plug it in ?!?!?!?
Did it worked before?
Test the USB ports first. Update BIOS download it from the Dell support. Try a different USB devices like flash sticks, external storage or other USB devices. If all external USB devices fails USB port might be defective. Call dell to replace motherboard.
Oct 01, 2009 | Dell Inspiron 1545 Notebook
Cant format 400gb usb flash drive
So the disk is recognized? And there is a valid partition on the disk?
What is the error you are getting?
Have a look at this external hard disk troubleshooting, maybe it helps you along.
Jules
Apr 21, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
Toshiba 8gb flash disk i cant format it or delete any file form it. pls help
toshiba 8gb flash disk i cant format it or delete any file form it. pls help
Feb 20, 2009 | Computers & Internet
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Feb 06, 2009 | Canon PowerShot G9 Digital Camera
When fitting a Canon 430EX flash to 450D,,light emits but flash doesnt fire, no flash in any mode.
Your camera may have been set to not fire external flash. Go to your menu, 5th tab. Near the bottom, there's an option for Flash Control. Select that. It should now show "Enable" or "Disable". Enable it.
Also "External Flash func. Setting" gives you more options for your 430EX.
Jan 25, 2009 | Canon EOS 450D Digital Camera
I cant use dsc h1 with strobe light
If you problem is that the double flash triggers the strobes early (on the first flash and the shot is made on the second flash - dark) you either:
1. Get a wire accessory to command the strobes
2. Put a simple external flash on top of the camera and use it to trigger strobes. If you don't need the light from this flash just point it up of backwards, it will still trigger the strobes. If it does not rotate, you can use tin foil. A very simple external flash will do, as the camera will flash only once with external flash.
Jan 09, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
External flash problems
Sounds like the external flash is being triggered by the pre-flash.
On the D40 set the flash mode to manual. On the F65 set the flash mode to Standard TTL.
Nov 28, 2007 | Nikon F65 35mm SLR Camera
External hard drive
Your system can't recognise the device and cant load the correct driver. Try to download the correct driver for your's operating system
Nov 12, 2007 | Toshiba 512MB USB 2.0 High-Speed Flash...
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
