Question about MSI PM8M-V Motherboard
MSI PM8M -V shaking/vibrating screen
My screen shakes violently whenever I start IE, OPERA or FIREFOX
  • logstock Oct 14, 2008
    hi there
              tks 4 yr reply. I tried installing an AGP graphics card but the problem still persists!   I then tried with a different monitor screen and I had the same problem. So we can rule out that it is the fault of the monitor. Any other way I can resolve this problem? Tks appreciate yr help.
Quiero los drivers para una board msi
Posted on Oct 19, 2008
    Problem Solver:
  • 18 Answers
Check the cable connection from the monitor to the computer for bent or damaged pins in the connector. Make sure it's connection is secure.
No problems found there?
try resetting your LCD or CRT monitor. Some CRT's can be degaussed, if yours can - try that.
LCD's, choose factor reset otion if available.
Still no luck?
Right click on the desktop and go to properties, then to settings, then to troubleshoot. Slide the hardware acceleration slider all the way to the left. Click OK.
If that doesnt solve your problem then you could have a bad video card or Monitor. If your video card is on your motherboard, try installing a PCI or AGP card ( if your system is AGP capable )
If you still have the shaking, you should start shopping for a monitor.
Hope this helps,
Posted on Oct 12, 2008
Whole car shakes
if the car shakes violently then have a wheel alignment done
if it is a vibration have the cv joints and drive line checked
other than that run the fault codes to check for misfiring problems.
Jun 15, 2015 | 2005 Mazda 6
I have a HotPoint washing machine, and it is leaking water bad. It leaks whenever the spin cycle starts, and the washing machine shakes pretty bad in that cycle. It's my ex girlfriends washing
The leaking could be coming from the exit port on the washing machine. Check the hoses leading from the washer to the drainage port in the wall. As for the shaking, check that the level adjustments at the bottom of the machine are level.
Apr 12, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
My 2005 ford ranger shakes violently at 70 mph
check for engine may shake when misfiring occurs!!! gud luck.. thanks for using fixya
Nov 01, 2009 | Computers & Internet
1993 Chevy S10, Hesitation in starting and shakes violently
check the fuel pressure regulator and see if it has a leak (common problem)
Apr 16, 2009 | 1993 Chevrolet S-10 Blazer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
My 98 Cherokee was shaking violently at 55 to 65 then it would stop shaking. I replaced the tires and had them balanced. It stopped all that. Give that a try
Nov 02, 2008 | 1998 Jeep Cherokee
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
MSI PM8M-V Motherboard Logo
228 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
