Question about Sub-Zero 661/F Side by Side Refrigerator
Sub zero refrig - ice forming inside
I have a 8 year old side by side sub zero refrigerator and ice is forming on the back left hand side of the refrigerator, what is causing this?
  • 5 more comments
  • alnak117 Oct 12, 2008
    Thank you very much, so I guess I have to call a Sub Zero repairman, doesn't sound like a DIY fix.
  • fabinfam Jan 30, 2009
    I have the same problem with a Sub Zero 561. Just had the refrig "sealed system" replaced under warranty (bought a house that had this refrig included and the frig side wasn't working at all) - the parts were covered, but I still had to pay $550 in labor.... Anyway, now the evaporator coils frost up. After the initial fix, I heard a boiling sound coming from the coils. I've taken the rear panel out of the refrig box and have exposed the back of the thermostat. Can someone further explain where the heating element is so I can check the resistance? Also, is there an easy way to check the thermostat functionality?
    Thanks - Dan
  • Anonymous Apr 30, 2009
    I just had my 19 year old Sub Zero 532 repaired due to ice forming on the left side of fridge compartment. The Evaporator and the Dryer was replaced. Due to the age of the unit the freon had to be replaced with the new coolant. The ice formation was due to a leak. Cost of the repair and parts $800.00
    Wheelshot was right on
  • Marat Brikov Mar 29, 2014
    https://www.youtube.com/watch?v=B-jwyofT...
    This is video how to fix this problem, its common problem with all sub zero models (side by side, or any other) and happens usualy on fresh food section. I have video of how I fix it on my channel, it was sub zero 600 series bottom freezer, but side by side will be exact fix link is below
  • Aoneprofessionalappliance Greatersacramentovalley
    Please never ever use any kind of pick or Sharp objects to remove the ice build up on any kind of evaporator unless you intend on replacing it. You are giving people the impression that it is an okay thing to do. A steamer is the appropriate tool, fast and efficient without damaging anything. Hot water is far to messy and takes longer to clean up, and any other source of heat like hair dryers or heat guns can damage the thermal shell.
    Please never ever use a pick or any kind of sharp object to remove ice from the evaporator. You are giving people the impression that it is an okay thing to do. Hot water is far to messy and takes longer to clean up, and any other source of heat like hair dryers or heat guns can damage the thermal shell. A steamer is the appropriate tool for the job. Fast and efficient without damaging anything else i.e. Thermal Shell, Evaporator, Plastics, etc.
    Scholar:
  • 102 Answers
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Posted on Apr 11, 2009
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 488 Answers
There is no heater in the fresh food section of sub zero. If you have frost or ice build up on the left of back wall, your sealed system failed, low on refrigerant, sub zero known for weak evaporator coils in fridge section. Here is how I fix it, check this video, put like or dislike on it, thanks ! THIS IS 100% What is wrong if you asking about refrigerator section!
Posted on Apr 17, 2014
    Genius:
  • 1,239 Answers
HI This component is a heating element located on the evaporator coil. When the refrigerator or freezer switches to the defrost cycle, the defrost heater is turned on to melt the frost in the compartment. Failure of the defrost heater causes failure to defrost.Test the element with a VOM set to the RX1 scale. To gain access to the heating element, remove the compartment's wall panels. Clip one probe of the VOM to each element terminal. The meter should read between 5 and 20 ohms. If it doesn't, the heating element is faulty and should be replaced. Replace the heater with a new one of the same type and electrical rating. Connect the new heater the same way the old one was connected.
Posted on Oct 12, 2008
    New Friend:
I need new shelves for my 48" ref. side by side
Posted on Jun 22, 2013
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Ice crystal formed in back of the refrig. how to get rid of this?
First of all, your freezer is freezing up DONT chip the ice!!!!!!!!!!!!!!! Either unplug the unit and allow it to thaw out naturally OR get a hair dryer or fan and let the ice thaw out. Then call us and we will be sure to get the right parts out to you to replace the defost system, which is out on your Sub Zero. We hope this does it for you and we also hope to hear back from you real soon. Ella
Sep 09, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Refrig section frosting up
repairing Sub Zero under warranty Sealed System. Evaporator Change Out HD video
Jul 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero Fridge not cooling and ice forming
You do have a leak and it will be in the evaporator. So call a factory authorized company and have it replaced.The warranty of a Sub Zero sealed system is full parts and labor for years 1-5 and parts only in year 6-12. Sub Zero expects a lot of their service companies so it behooves you to call one. To find an authorized company go to http://www.subzero.com/locator/locator.aspx?type=0&zip= or call 800-222-7820
May 31, 2008 | Sub-Zero 601R
Sub-Zero 661/F Side by Side Refrigerator Logo
3,660 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal De GO PATS
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
