Just bought a new Sharp LC-32SB24U and when I hooked it up it has no volume. Went through the audio menu and still have had no luck. All I have hooked up to it is the cable. What else could it be?
  • fjackie13 Oct 12, 2008
    I just bought a new Sharp LC-32SB24U LCD television and after hooking it up it has no volume. Already went through the audio menu with no luck. All I have hooked to it the cable. What els could it be?
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
sarskie
  • 9 Answers
SOURCE: 20" sharp lcd, no sound
Gud day..you check first ur cable then ur speakers.. even the connectors and jacks...
Posted on Mar 08, 2008
  • 126 Answers
SOURCE: I just purchased this LC-32SB24U
may be bad tuner not sure on this model if you can re -solder
ground points or not
Posted on Jun 07, 2008
  • 927 Answers
SOURCE: LC-32SB24U LCD HDTV... Brand new,
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Posted on Aug 07, 2008
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Sharp flat tv lc-32sb24u no audio was watching tv last night and the sound just stopped in the middle of a show. picture is perfect. is it worth to fix.
Sir try to check the cables connection at the back of your tv. and if you are using a digital receiver, try to use a dvd to check if there is a sound. If there is a sound the problem is the digital receiver, feel free to send feed back good day and best regards.
Aug 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
I want to hook headphone to my Sharp's 32SB24U TV. I plugged in to audio jack, but the sound is not coming out from headphone. It's still coming out from TV's speaker. Do I need to do someting...
That jack is meant for connecting to Home Theater Systems or to computers not for headphones but it may still work. If you go to your menu and find Output Select change this option to variable. On the off chance it works you might want to be careful when testing... it may lead to sudden deafness if its too loud. By the way this will turn off the sound coming from your speakers.
Hope that helps!
Jul 19, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Sharp lc-32sb24u need owners manual
here is direct from SHARP (appears to be same one Silverdragon just posted seconds before me...)
SEE
http://www.sharp.ca/manuals/default2.asp
scroll down to "LC32SB24U Operation Manual 1.63 Mb EXE" and select the corresponding [download] button.
(there is entry for French too just below it)
the downloaded file is LC32SB24U_OM.exe
this extracts to LC32SB24U_OM.pdf
...which is the Sharp LC-32SB24U and LC-37SB24U Operational Manual in English. You need Adobe Reader to view PDF file.
Good Luck!
Mar 10, 2010 | Televison & Video
Sharp LC-32SB24U TV. Remote no longer functions.
Unplu the TV from the wall, wait for 30 sec. plug it back in.
Nov 07, 2009 | Sharp 32C-240 32" TV
I need to receive a manual on the operation of my sharp tv
I believe your TV is a LC-32SB24U, not LC-325B24U.
You can download a manual at www.sharp.ca/manuals
Feb 21, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Our new Sharp LC-32SB24U has a box that comes and goes on the upper right hand corner that says audio and flahses the words stereo and audio and then goes away..any ideas?
Change up your connection. If you have a cable/satellite box, get rid of that coax cable connection and use red white and yellow RCA cables to connect and that will take care of the problem. if you dont have a cable box(but i bet you do), you will need to run your cable through another device because you cant do anything to turn that off. another device such as a vcr, cable box, or a converter box. hope that takes care of it, good luck 2u
Jan 04, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Remote control tv codes for sharp lc-32sb24u tv
Oct 21, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Do this:
1. UNPLUG TV
Aug 07, 2008 | Sharp Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
