Question about Dell 5100cn Laser Printer
Dell 5110cn Printer Problem
Hi, Thanks for being here for us! I see that you have responded to similar questions, so I thought I'd pick your brain if you don't mind.
Our Dell 5110cn color laser printer stopped printing black ink yesterday. It started fading out and streaking early in the day and now there is only a thin streak of black on one long edge. However, the colors print fine. From reading the other posts, I am guessing the the black developer has gone bad. One of my questions is this: How certain are you that this is the problem? I will order the part and attempt the install myself, but I'd like to be as sure as possible that this is the problem before I attempt it. Is there any other likely cause? By the way, is Dell the only place to order this part (or any part) or are there other, perhaps better, places to purchase Dell parts?
Another question is this: Do you know of any step-by-step directions for installing the developer if that is the problem? I live in the middle-of-nowhere, relatively speaking, and technicians are not readily available. So, I guess I'm game for the install if it's possible to do with good directions.
Thank you in advance for any information you can give me. My email address is caroline.jensen@k12.sd.us . If you would like to respond, that would be an easy way to chat with me. Thanks!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Looks like this is a duplicate post from the last one that I already replied to.
I will just continue to help on the other one .
Thanks,
Cory
Posted on Oct 12, 2008
Grinding noise Dell 5110cn
Grinding noise usually is a mechanical issue with printer. It could be because of any obstruction in the carriage mechanism or the gears.
If your printer is In-Warranty ( within 12 months from the day you purchased it ), then you should be calling Dell for Free Replacement.
If your printer is Out of Warranty, I still suggest you call Dell as they may offer you a better deal for your printer.
Regards,
Suhail
May 16, 2012 | Dell 5110cn Laser Printer
Our Dell printer is asking to load paper, when it already almost full. What should I do?
The only solution i have for you is just for you to make sure the papers been loaded is touching the end of the paper carrier side unless it won't pick any paper. And please make sure every tray of the printer is placed well. Thank you.
Best of luck.
Feb 14, 2011 | Dell 5110cn Laser Printer
Donde encuentro manuales de esta impresora DELL 5319n
Workgroup Laser Printers Contents: Dell Laser Printer 5210n/5310n Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Dell Support ...Dell 3115cn Color Laser Multifunction Printer - Dell 3130cn Color Laser Printer - Dell 5210n Mono Laser Printer - Dell 5310n Mono Laser Printer - Dell 5330dn Mono Laser Printer - Dell 7330dn Mono Laser Printer...
Documentation ...Printer 5110cn Dell Laser Printer 5210n / 5310n Dell 5350dn Laser Printer Dell 7130cdn...
Documentation Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Support Information Matrix for Dell Management Console Version 1.1 ...Color Laser Printer 5110cn Laser Printer 5210n/5310n Laser Printer S2500 (n) Workgroup Color... 5330dn Dell 7330dn Dell 2145cn ...
Systems Management Supported Information: Dell Management Console Version 1.0 User's Guide ... Dell PowerVault ...Dell PowerConnect ...Dell'EMC ...Laser Printer 1815n ...Laser Printer 5210n/5310n Yes ...
Dec 13, 2010 | Dell 5310n Laser Printer
Dell 5110cn, says change magenta toner, crum 093-961. canged toner. still has same display
Your Toner Dispenser TF123 could be bad. It is probably not reading the chip on the Toner.
Or possibly you are using the wrong toner. Dell 5100 or Xerox 6300 looks similar and might fit. Also, if you are using 3rd party toner, check that they have caused your problem.
Whit
Item, Inc.
Aug 24, 2010 | Dell 5110cn Laser Printer
HOW DO WE RESET NUMBER OF RINGS FOR FAX TO ANSWER?
Please select the correct device before submitting a question. The Dell 5110cn laser printer that you've submitted a question for isn't a multifunction that does fax.
Jan 22, 2010 | Dell 5110cn Laser Printer
Hi Caroline,
Thank you for using Fixya.
From what you mentioned, it does sound like you may have a defective black developer, especially since the rest of the colors are still functional.
The imaging drum COULD cause this as well, even if the other colors are working, as the primary transfer still has involves a photo conductor that acts independent of the other 3 colors.
Before you swap out any parts, do try this... using the control panel, lets try to clean the black developer unit. what this does is cause the auger to move toner from the cartridge to the black developer and insures that there is in fact toner in the developer.
click on the menu button, scroll to select maintenance, then developer cleaning, then select black.
try printing again after that.
If that does not fix the issue, again before spending money on repairs, I would try a new ( or an old one if you did not get rid of it ) imaging drum. If that fixes the problem, then it needed to be changed. if it does not, it IS a consumable and will need to be changed in the future anyway, you can put the old one back in and the new one back in the silver pouch and reseal it until you need it.
if neither of those two things work, then the next step would be the developer itself.
I am sure you can purchase the item from Dell. I have not looked, but usually you can do a google and/or ebay search for any Dell part number as well and find it for sale that was as well.
Good Luck :)
Oct 12, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Printer Printing Blue Shadows
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
Hope it helps
Aug 16, 2008 | Dell 5110cn Laser Printer
What is the hard reset for Dell 5110cn
I have a dell 5110 cn laser printer and the transfer roller just went out.. How can I re-set this since I do not have a replacement roller. but i need ot order. Thanks
Apr 19, 2008 | Dell 5110cn Laser Printer
Dell 5100cn Laser Printer Logo
287 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
