Question about Sub-Zero 661/F Side by Side Refrigerator
Ice is forming inside the refrigerator
I have a 8 year old side by side sub zero refrigerator and ice is forming on the back of the inside wall of the refrigerator on the left side, what is causing this?
  • 725 Answers
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Posted on Oct 12, 2008
Sub zero 690 side by side help
I need more information to assist you. Which section are you having issues with? Do you have fault codes (these will flash on screen inside unit)? Have you cleaned the condenser (if not please do so)? Do you have ice forming anywhere on the walls? Please get back to me when you can with answers to these questions. Thanks
Jul 26, 2014 | Sub-Zero 690 Side by Side Refrigerator
Ice build up
Hi
is it brand new?
Jul 15, 2008 | Sub-Zero 632 / S
ICE IS FORMONG ON THE BACK WALL OF A SIDE BY SIDE SUB ZERO REFIGERATOR.
This is typically a problem with the sealed system (refrigerant leak). Usually a circular patch of ice or water driplets half way down on the back wall. The solution involves replacing the evaporator coil. Subzero will give partial warranty up to 12 years.Full warranty for 5.A subzero authorized company is recomended.
Sep 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice on back wall of fridge
The ice forming on the back wall of your sub zero indicates that you have a part failure. I don't recall exactly what the part is but as soon as you mention your symptoms to a sub zero repairman he'll know your problem. It's an easy fix. Everything comes out of the fridge, takes the inside back wall off and replaces the part. Not an inexpensive repair, however the part is guaranteed for 5 years so you may have an opportunity to have it replaced under warranty as I did.
Sep 07, 2009 | Sub-Zero 632 / S
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero freezer 600 series - flashing 'vacuum condenser'. I've taken the vents off and cleaned areas, however, the message light does not come off. And the freezer has formed ice on the back walls.
Our is doing the same thing, except we do not have ice forming on the back of the freezer. We were told by a refrigeration repair company that if ice is forming on the back of the freezer then the compressor is bad.
Sep 17, 2008 | Sub-Zero Refrigerators
Sub-zero Fridge not cooling and ice forming
You do have a leak and it will be in the evaporator. So call a factory authorized company and have it replaced.The warranty of a Sub Zero sealed system is full parts and labor for years 1-5 and parts only in year 6-12. Sub Zero expects a lot of their service companies so it behooves you to call one. To find an authorized company go to http://www.subzero.com/locator/locator.aspx?type=0&zip= or call 800-222-7820
May 31, 2008 | Sub-Zero 601R
Sub-zero 532 problem
you have a Freon Leak @ the Evaporator.. Ice ball on back wall.. left side....
Apr 15, 2008 | Sub-Zero 632 / S
Sub-Zero 661/F Side by Side Refrigerator Logo
501 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
