Question about Canon PowerShot S410 / IXUS 430 Digital Camera
S410 What is error E18? Installed new battery and receive loud noise and E18? Worth fixing or buy a new camera?
    President:
  • 1,113 Answers
The E18 error happens on Canon cameras usually when the lens is jammed when extending.
The error is so (in)famous that it has it own website where you can find help and advice on how to fix it. You can view the site by clicking the link underlined in blue below:
http://www.e18error.com/
There is also a Wikipedia entry which you may find helpful:
http://en.wikipedia.org/wiki/E18_error
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Posted on Oct 12, 2008
What does E18 mean
Lens error. Try http://www.e18error.com/ for help on fixing it.
Jun 29, 2014 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Power Shot S410 shows E18
The following blog outlines some repair options for a E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 26, 2009 | Canon Cameras
Have Canon PowerShot A80. New batteries, turn on and it automatically turns off with a buzzing/clicking noise... Window shows error E18
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try:
Nov 14, 2009 | Canon PowerShot A80 Digital Camera
Camera powered on, lenses extended, then got an E18 error message. Won't take pics, lenses won't retract. Tried charging battery, no difference. Powers up, powers off, that's it.
Canon E18 error happens when the lens gets stuck while trying to extend.
There is a step-by-step tutorial (with pictures) for fixing this yourself on this website, which is too long to re-post here.
You can also try tapping the USB port lightly against a hard surface, and using compressed air to blow out the area between the camera body and the lens turret.
If you can't fix it yourself and decide to send the camera back for repair, be warned that Canon has horrible customer support and response time. You might want to consider replacing the camera instead.
Oct 25, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Powershot A80 error E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 05, 2009 | Canon PowerShot A80 Digital Camera
What is the E18 error and how do I fix it?
Lens errors (a.k.a. E18 errors on Canons) are fairly common in all digital cameras. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 04, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon powershot s410
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Apr 22, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Canon pwershot s1 IS E18 error code
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 14, 2008 | Canon PowerShot S1 IS Digital Camera
Camera frozen, emits a buzz and "E18" in the lower left hand corner
Assuming you have tried the repair people on this site first, and need to follow it up further, I have found a site which gives some insight and proposes a fix if you would like to view it, it's at www.e18error.com They explain the problem like so:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
They also say how you may be able to fix it yourself - which is nice - well worth a visit! Hope this helps
Nov 28, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Unusable
This is a hardware problem common with many Canon cameras. Unfortunately, there is no easy way to fix this. Canon can fix it for you, but they charge more to fix it than it would probably cost to replace the camera. There are entire sites dedicated to those who've had this error, but there is no way to fix it short of sending it in to Canon. One such site is here: http://e18.bitnet.cx/comments.php
Aug 28, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
