Question about Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum
Brush won't spin on my Hoover Mach 5
I've replaced the belts already but the brush won't spin
  • 4 more comments
  • lmoore873 Nov 17, 2008
    replaced all belts and still brush will not turn
  • uk21platinum Nov 26, 2008
    I have the same problem. I have not had the vacuum cleaner for a year and the brush stopped spinning. The belts seem fine. Also the button for Carpet won't switch over to the "ON" position.
  • coloradocraf Dec 27, 2008
    my brush stopped working also. my husband thinks its a design flaw. does anyone have a solution?
  • Anonymous Mar 31, 2009
    Replaced both belts, cleaned roller.....brush still will not turn. It seems the V Belt is too loose. I have had mine for a little over a year. Makes me mad.......I loved it when it worked. It WAS the best vacuum I ever had.
  • mcevoy Apr 04, 2009
    Mine did the same thing.. took it to the repair shop and there was another one sitting there with the same problem. Has anyone contacted Hoover?
  • Anonymous Apr 11, 2009
    brush stopped turnning
I love this vacuum but had the same problem.
SOLUTION:
take the roller off and flip the thin belt inside out. This fixed my vac and works great again.
Posted on Nov 23, 2009
  • lbeach8888 Jan 20, 2011
    Yep, that did the trick! Thanks!!!
  • CALIMERMAID Aug 10, 2011
    wow, my vac has been sitting in the basement for 7 months because it wont pick up like it should, i decided to check out this forum and did what you said, flipped the belt inside out, it worked like a charm. my vac is back to new!! THANK YOU THANK YOU THANK YOU!!
I found a Mach 5 at the dumpster area of our apts. Could'nt believe somebody was getting rid of it. Looked brand new.
When I tried it the roller would'nt turn. Same problem, V-belt looks to big. I turned the belt like was suggested and it worked. Works great. It needs a little bit smaller belt.
So try the belt flat side down.
Posted on Dec 18, 2009
  • Tracey Martella
    Tracey Martella Mar 31, 2014
    I did turn the belt around and the host of heavenlies began to sing when I turned on the vacuum and it performs like new!!!!! Thank you!!!
Snorr, I just had to thank you. You saved me alot of time, money, and frustration!!!
Posted on Mar 13, 2010
SNORR, thank you so much! You saved me from buying a new vaccuum. You're solution worked for me! After a couple of hours tinkering with it I had just about given p, I have never thought of reversing the belt.
Posted on Jan 22, 2010
  • Neal Ruff
    Neal Ruff Feb 17, 2011
    I did the same and figured out the roller only turns when the handle is down !!
Hoover windtunnel U5453-900.belt melted put another belt on brush was spinning.Brush spins but not easily.It spins then stops therefore burns the belt.How can i get the brush to spin around better
Kristie,
I would suggest taking the brush bearings at each end off and clean any lint or hair that might be in the ends of the brush. If you have regular ball bearings on your brush, you might need to replace the brush roller if the bearings themselves are tight. Hope this helps!
Apr 05, 2015 | Hoover Vacuums
Vaccum not turning or sucking
It definitely sounds like your belt is broken. If something gets vacuumed up into the brushes, and prevents the brushes from spinning, the motor will continue to try and spin the belt and the brush, but since the brushes can't spin, this will burn right through most belts.
Especially since you mentioned a sock being sucked up, and the roller brush not spinning, this is a tell tale sign of your belt needing replacing.
Here's what you'll need to complete this repair:
- Phillips Head Screw Driver
- Hoover Windtunnel Replacement Belt, Non-Self Propelled, Hoover Part # 38528033
- Depending on how long the sock was stuck in the brush, you may need a new roller brush as well. The roller brush for your model is Hoover Part # 48414110. Here's a direct link for the roller brush for your vacuum on our website:
http://www.govacuum.com/generic-hoover-windtunnel-tempo-fusion-upright-12-inch-replacement-roller-brush-hoover-part-number-4.html
If you have the Hoover Tempo Widepath vacuum that you listed the repair under, then here's a direct link back to our website, govacuum dot com, to the exact belt for your Hoover Tempo:
http://www.govacuum.com/agbelhoovpar9.html
Now, once you have a new belt, this repair is pretty straight forward. I'll explain step by step what you'll need to do to change the belt.
Step 1. Make sure your vacuum cleaner is unplugged. The easiest way to change the belt in your vacuum is to turn the machine upside down, so the handle is on the ground holding it up, then lean the vacuum over a counter top or work bench.
Step 2. Remove the bottom plate of your vacuum cleaner. You'll see on the bottom of the vacuum 4 screws that are located on each corner of the brush, remove all 4 screws, and lift up on the bottom plate that covers the roller brush.
Step 3. After removing the bottom plate, you should now be able to access the roller brush completely, and you'll probably also notice that the belt on the right side of the roller brush is broken. You may just remove the broken belt completely and throw it away. Lift straight up on the roller brush itself to remove it from the vacuum.
Step 4. Test the roller brush. After something gets stuck in the brushes, and it causes the belt to burn, there's also a good possibility that your roller brush may need replacing as well. Also the roller brush will wear down over time, and the brushes will wear down as well, greatly reducing the cleaning ability of your vacuum. You'll want to test your roller brush, to ensure that it spins freely. If it doesn't, then as you install the new belt, it's possible it could also break immediately. To test the roller brush, remove it completely from the vacuum. Holding just the end caps of the bar with your fingertips, try to spin the brush in your hands using your thumbs. This is how it should look when you test your brush (the roller brush is to a different machine, but testing it will work the same):
The roller brush should spin at least 3 or 4 times in your hands on each spin. If the brush will not spin at all, or you feel some resistance when spinning it, then you'll probably want to go ahead and replace the roller brush as well at this point.
Step 5. Once you have your new belt, and new roller brush (if needed), it's time to install them. First wrap one side of the belt over the metal motor pulley in the back of the vacuum, opposite the roller brush. Now after you have one side of the belt wrapped around this metal pin, put the roller brush through the other end of the belt. Using the roller brush as leverage, stretch the belt with the roller brush inside of it back into the roller brush tray. You'll notice that on the left bearing cap on the end of the roller brush, there's a little rectangular shaped notch. Make sure that the rectangular notch is vertical, and slide this end into the agitator housing first, then fit the other side (circular notch) into the housing. With a little bit of elbow grease, you'll be able to stretch the brush with the belt back into place.
Step 6. Test the belt and the brush before putting the bottom plate back on. To make sure that belt and brush are properly installed, pull the belt forward towards the brush, and make sure that the brush spins while you're pulling the belt. If the brush does not spin, then either the belt is pinched underneath of the roller brush, or the brush is bad / installed incorrectly. Make sure that the brush spins freely before reinstalling the bottom the plate, otherwise the belt will burn and break again as soon as you turn on the vacuum.
Step 7. Reinstall the bottom plate, and screw down the four screws. Now you can turn the vacuum on, and make sure that the brush is spinning. If the brush is not spinning, repeat the steps above to make sure that the belt and brush were put in correctly.
That should fix your problem. Ideally you should change your belt at least once a year. Even if the belt doesn't break, it will stretch out. When the belt is stretched out, it will not pick up as well as a new belt will.
If you have any problems, or questions about how to do it, please feel free to use the Clarification Request here on the Fixya repair page, and I'll be more then happy to answer any follow questions for you.
Here's a link to the owners manual for your model that will also give you diagrammed pictures of how to replace your belt.
http://www.hoover.com/pdfs/manuals/U5140900.pdf
If you found this repair helpful, please be sure to rate this repair helpful by clicking the thumbs up icons. This small token of appreciation keeps Fixya repair experts continue posting free repairs to help the community. Thank you very much, that's greatly appreciated.
Chris J.
GoVacuum
Apr 07, 2010 | Hoover Tempo Widepath Upright Vacuum -...
I replaced the belt with part# 40201 on my Hoover model# U5473-900; to only have it break again in 5 seconds! Is there something missing that holds it on that little bar?
Greetings,
When a brand new belt breaks in 5 seconds, this can only mean 1 of 2 things.
1. The roller brush itself may be bad and need replacing. If the roller brush's bearings lock up, and the brush can no longer spin freely, this will cause the belt to burn up immediately after you turn the vacuum on. You may test your roller brush by taking it out of the vacuum, and hold it on the very ends of the brush with your fingertips. Make sure you are only holding the bearing caps and not the brush itself. While holding the two bearing caps with your pointer fingers, try to spin the brush with your thumbs. Does the brush spin freely? If no, then you'll need to buy a new roller bush for your vacuum, unfortunately the bearings are not sold separately on Hoover vacuums. If the brush did spin freely (you should get at least 7 rotations out of one spin) then see reason number 2 below.
Your model uses Hoover Agitator Brush Part 48414132.
2. The belt was installed incorrectly. When a belt breaks immediately like this it can also be a result of it not being installed properly. When installing the next belt, after you have put the roller brush back into place, pull forward on the belt to make sure that the brush spins when you're pulling forward. Sometimes I pinch the belt underneath of the brush roller, and it will not spin freely, and will burn immediately if the belt is pinched.
It really can only be one of these two problems. I hope that this repair solution was helpful to you. If you need me to clarify something, please just request clarification here. If it did help, please be sure to rate my repair Helpful. Thank you so much!
Chris J.
Mar 13, 2010 | Hoover Vacuums
On our Hoover U6445-900 (Mach 6.9) we replaced the small belt that goes to beater brushes in front of unit. Upon starting, the Hoover quickly got hot and smoky. We shut it off and looked things over...
are you sure you purchased the right size belt..the friction you speak of is usually caused by a belt not being the right tightness or a jammed beater brush
Dec 19, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Oct 29, 2009 | Hoover Vacuums
Hoover mach 5 turns off after 10 minutes of use
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
Another item to check is if your dust filter is not plugged up which is located behind the removable dirt cup. This is the cup that you remove that collects the dust/dirt/hair from your floor. Take the removable dirt cup out by depressing the gold button and then look behind where the dirt cup sits for filter. This can be cleaned out by washing it with soap and water in the sink but make sure you let it dry overnight before placing it back in the machine. This probably causes some of the overheating when not enough clean air is passing through the machine.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Oct 01, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
We replace the belt on our hoover mach 6 but the brush doesn't spin.
is the motor spinning? If not, it will need to be replaced. If it is, the bearings on the end of the brushes may be stuck
Jul 07, 2009 | Vacuums
My brush will not turn, and the brush control is stuck on "off"
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum Logo
2,274 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
