Question about Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre monitor just wondering what capacitor was the one you replaced for the monitor. mine stays on for 2 seconds then shuts off.
    Problem Solver:
  • 5 Answers
I would suggest looking at the capacitors on the power supply board. I just got one today with 3 blown caps (the tops are swollen) and a couple missing components.
The ones blown on mine are the 220uF @ 25V and 1000uF @ 16V.
Posted on Feb 12, 2009
  • Cheezmo Feb 12, 2009
    Also, when you get yours open, can you look near the inductor coils and see if R88 and C65 are present and if so, what values
    they are? It seems to be common missing pieces so I almost think they
    are meant to be removed.
  • Cheezmo Mar 21, 2009
    yes, these components have been factory removed :)
Sceptre Monitor P/N X7G-Komodo II displays for about 1 second at a time, then goes black. When I cycle monitor power, I see a perfect display for 1 second. Does anyone have a recommended solution?
When the backlight does not stay on for more than a second, the problem is usually the backlight power supply board failure. Typical failures are blown capacitors, or transistors. A electronic repair shop should be able to fix it.
Oct 05, 2010 | Sceptre X7G Komodo II 17 in. Flat Panel...
Same problem here
My Sceptre Komodo 19 would turn on for less than a second than turn off. Eventually, I could get it to stay up. But after a month, I couldn't get it to stay on anymore.
I found the solution on this website. There are some bad capacitors... 4 of them for about $2 worth. I replaced all four and the monitor works fine again. They are soldered in. They are polarized; they need to be installed the right way. The white stripe goes towards the “wall”.
2 are 470uf 25v and 2 are 1200uf 10v.
I ordered mine for about $10 with shipping from Mouser.com
661-EKZE250ETD471MJ1 and 647-UHE1A122MPD
Oct 04, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre LCD - no display
It may be the capacitors, since capacitors run about $1.50 or so depending on size you may spend a little over $6 total if you already have soldering equipment or a friend with skills.
Feb 27, 2009 | Computers & Internet
Montior Repeatedly Shuts Off/Goes Black
i have the same problem .
already know what it is .
its the cfl power inverters which are build into the power supply
easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre X20G Naga II 20.1" Widescreen monitor
I am working on one of these for a customer. Found leaky cap on 5 volt power supply. replaced it, still no backlight. Looked at the inverter with an o-scope and it runs for a few seconds then shuts off. I hooked a ccfl across each of the transformer secondaries on the inverter and it lit up! I believe the problem is failed ccfl units. There is plenty of voltage there to light them up, I have an rf burn on my thumb to show for it. I have not looked at the ease of dis-assembly of the display to replace the backlights. It does not look easy.
Oct 22, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Same Flashing Problem
Jul 06, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor Powers off after a second or two.........
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
Sceptre X9G-NagaIV 19" LCD Monitor Logo
426 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
