I bought a home built in 1935 with a Perfection Brand gas forced air heater, any info or a website on this old brand of heater would be greately appreciated. I was told it is over 25 years old, I just want to read about this heater and get to know how it works, until I get money to purchase a new one. Thanks in advance.
  • 124 Answers
Any and i mean any ac and heat company you call in the yellow pages can and will be happy to repair yor heater. parts are all generic. problem is the heat exchanger needs to be tested every year with a co detector so no one gets killed. thats pretty blunt but hey its true. gas is nothing to play around the gas company and they will usually test it for you. maybe for free. all heaters work the same. stat says heat , if pilot is lit then thewrmocouple senses heat and oks main gas valve to open then burner lights and a while later blower comnes on and blows hot air into house. question is , are air and chimmney gases mixingin furnace? test with co detector.does flame lift on burners? observe and compare with your previoys observations. my gut feeling is that consummer reports says 9 to 13 years is a life span on a ne wunit , your messing around with a old piece of equipment. it doesn't care about your finances, it will fail and harm you when its time comes reguardless ....
Posted on Oct 18, 2008
Brand new rennai tankless hot water heater installed on newly built home. Rl75e model need to purge for the first time
Gas line I take it . You will need to purge from the outlet of the meter first to make sure service line and meter are clear of air . And then close to the heater make sure its well vented and no source of ignition soap test any joints you loosen .
Apr 25, 2017 | Water Water Heaters
Performance ratings for gas hot water heaters? Where can I obtain said info?
If you pick a brand, the site will have the ratings. There are also some resources on energy websites. The best rated water heaters for energy ratings are very expensive because they are the tankless models. If you don't want to spend thousands on a water heater, I would recommend RHEEM brand heaters. If you are replacing an older unit you need to know that the newer models are bigger and may not fit directly in the place of the old one.
Mar 17, 2017 | Water Water Heaters
I bought a brand new house and the gas water heater seems to be stuck in vacation mode.
Copy following link to troubleshoot by type of gas control valve, instructions how-to-light-water-heater, including error codes etc:
To reset the intellivent gas control, press and hold both arrow buttons for about 5 seconds
This water heater requires pilot flame. Look through site glass and upward (or use mirror) to see if pilot is ON and burning clear blue flame and not lazy yellow flame.
Check that gas shut-off is parallel to gas line:
Check if outlet has 120Volt, and that polarity of outlet is correct. Power vent water heaters require correct polarity: use circuit analyzer. Check if there is ground continuity between ground and manifold tube (center tube that connects between burner and gas control valve).
Scroll to top of same link to read about FV system and air intake cleaning. Must have good supply of incoming air.
Same page half way down has troubleshoot section for pressure switch testing, blower troubleshoot etc. The pressure switch and blower communicate electrically with gas control thermostat to determine when to release gas to burner where pilot ignites gas, causing poisonous combustion by-product to vent outdoors and help nature.
This model has thermopile instead of thermocouple. Basically thermopile is several thermocouples. When heated, thermopile generates enough current to run small electronic circuit inside gas control valve. This circuitry is very common in hvac units but fairly recent to water heaters. Advantage is error code troubleshoot and more optional controls, for example future response to in-home zwave remote controls and home automation
Get model number and brand from label on side of tank and post question on pro water heater forum with list of what you have tried so far.
Call plumber to bleed air out of gas line and check gas pressure.
May 28, 2013 | Water Heaters
Problem keeping my Rheem hot water heater light
What brand, model, and approximately how old is water heater?
This is important because water heater designs are changing quickly.
Did you remove door over combustion chamber to access thermocouple?
Newer Rheem water heaters have air intake under combustion chamber that has to be blown out using compressed air.
If this is different brand, then use mirror under water heater to see air intake.
Set water heater on bricks to avoid high water. Make sure drain line out of drip pan is 3/4" and terminates in good drainage location.
Put brass garden hose cap over drain valve.
Aug 29, 2012 | Rheem RHG Pro40-40F Pro Series Natural Gas...
Gas water heater
More information is needed.
What brand and model of water heater, and about how old is the heater?
Get more fresh air to the unit, and clean the air intake.
Copy following links for pilot troubleshoot, and general troubleshoot.
Aug 24, 2012 | Water Heaters
I have Wiiliams direct vent wall furnace. I smell gas only when pilot is on and burner is not on. It does not smell when it is fully running (burner is on)
Dear Alex191: I am shocked and amazed that the Williams heater company is STILL knowingly and willingly selling faulty direct vent gas heaters. My problems took place in 1988! I bought a 30,000 BTU Williams DIRECT VENT from The Home Depot. I took the time to remove window sashes and run gas line to the Williams heater that I had placed in the window aperture. I was glad to finally have heat and be able to heat the area of the house where I stayed. Then I began to smell gas when the Williams was OFF. I traced it to the area where the pilot light gas tubing entered the combustion chamber. I removed the Williams unit and replaced it with an identical make and model and the SAME THING HAPPENED!!! I sat on my bed and almost cried. I had the gas company come out and they labled the problem as a "fuzz leak". The warranty repairman came out and had no idea what to do. Tightening the retaining nut did nothing. I called Williams and even back then they said that they were aware of the problem. They called me back and wanted to send me a part and asked me, "Can you work on it?" I returned the Williams and bought a Perfection-Schwank CONSOL heater that burns the air in the room and vents horizontally to a 4 inch vertical gas vent and was very satisfied with it. When they went out of business I bought an "Empire" brand gas heater. I don't know if I'll ever buy another direct vent heater from anyone. I will be glad to write an affidavit should you decide to suit the Williams company.
Feb 20, 2010 | Williams 1403622 Gas Compact Heater
Hi, I need parts for a kerosene torpedo heater.
You need to call Portable Heater Part in Valparasio,in for replacement parts
Oct 07, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Coleman heater needs coil to hook up coleman a/c unit
your going to need a cooling coil and a condenser unit. your local contractor can get same brand from supply house. maybe online e bay
Aug 26, 2009 | Coleman Propane Forced Air Heater...
Heater will not stay lit
Leave automatic button depressed for 30 seconds after flame ignites.
Jan 14, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
DCS DRH-48 Natural Gas Built in Heater Won't Light
I have worked on two units and have had several problems with them. On a new install like you described, it may be that you have to purge the air out of the gas line. Do you smell natural gas at the unit? If not, then you can open the front control panel cover and unscrew the purge valve on the gas valve. This is assuming that you do hear the gas/air flowing when the unit is turned on.
If the units lights, then goes out, then there is a problem with the heater sensor portion. check to make sure the white wires are all connected inside.
If things still don't work, then the problem may be beyond this short answer.
Good Luck
Dec 23, 2008 | DCS DRH-48N Patio Heater
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
