Question about Philips GOGEAR SA6045 MP3 Player
Blinking philips sa6045 mp3 player.
My mp3 player is dead. when i try to charge it off the wall, or with the computer, all it does is blink for about a minute, then nothing! the computer doesnt even read it. please help.
  • 8,596 Answers
Make sure the hold/lock switch is not engaged - see manual for details. Probably needs to be replaced - that is a sure sign of a hardware issue, and it is not something that can just be repaired. but, just to be safe, try this:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
When I try to turn on the MP3 (Philips GoGear Mix) I see a symbol of a battery and then it shuts down. When I plug the MP3 to the computer it shows it is fully charged. What shell I do? Thanks
I have had a GoGear for a while and those things have horrible firmware and are very fragile. I have experienced the same issue myself, so I suggest leaving it plugged in for several hours no matter what the screen says to try and let it charge. It should charge up. If not, try charging via a usb wall charger, which should allow usage of the player while it charges.
Jun 01, 2011 | Philips GOGEAR SA6045 MP3 Player
My mp3 player just blinks when i try to charage it
Make sure you are using the correct power cable. If you are charging from USB and it still blinks, you may need to contact Philips for service. If you are charging from a wall outlet, try using the USB cable instead to eliminate the possibility of a wrong cord.
Apr 17, 2011 | Philips SA3125\02 MP3 Player
My mp3 player won't do anything!!
Hello there,
It is unlikely that the player is dead but the Usb cable or USB/charging port or the battery is dead. If the player is under warranty you can demand for a replacement. Otherwise check if a replacement usb cable would fix the issue. Otherwise its going to cost you around $30 for repairs.
Sai.
Feb 15, 2009 | Philips GOGEAR SA6045 MP3 Player
Can't charge, computer doesn't recognize
-Tha Mp3 Doctor
Oct 10, 2008 | Philips GOGEAR SA6045 MP3 Player
MP3 connector
Call Philips to get the original charger, or go to Radio Shack to get a "USB wall charger" (5V) - or do both. It is your choice.
Aug 20, 2008 | Philips GOGEAR SA6045 MP3 Player
Help
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Aug 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Hi this is about my zen mp3 player
Jul 07, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
71 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
