Question about Toastmaster TPC2 Popcorn Maker
Directions for use.
I just opened the package and there are no directions to show how much popcorn (cups of kernels) to put in.
  • guencat Oct 12, 2008
    toastmaster tpc2. That's all I have. Where would the model number be?
    Scholar:
  • 157 Answers
Hello guencat. Send me Mgf. & model and I will find an answer for you.
Posted on Oct 12, 2008
  • Gene Pitts Oct 13, 2008
    Hello guencat. Who made the toast master? Most of the time the manufacture name and model number is located close to where the AC power cord inters the device or on the bottom of the unit. Do you have the box it was packed in? Check all sides of the box, its there somewhere.
  • Gene Pitts Oct 26, 2008
    Hello guencat, Did we find the lost treasure?
Directions for use. Do I preheat and how much kernels do I put in?
Yes, you should preheat the kettle some. Each model varies on the amount of kernels. 2,4,6,8,12,14,16,20,32 ounce machines are common. Search your popcorn make and model to find out the popcorn recipe.
Oct 07, 2014 | Kitchen Appliances - Others
How much oil, corn and salt do I put in a 2085cl gold medal popcorn machine?
That model is a 6oz popcorn machine.
3/4 cup popcorn kernels (6oz)
slight 1/4 cup oil (1.6oz-a quarter cup is 2 oz.)
1 teaspoon popcorn salt.
Sep 17, 2013 | Gold Medal Kitchen Appliances - Others
Manual needed for # OFP-501
I got persistent following a Yahoo.com search:
This is a 12-page PDF file:
http://nostalgiaelectrics.com/manuals/ofp-501.pdf
The kernel measuring cup is pictured on page 6, and its capacity is 6 tablespoons (=18 teaspoons).
Oct 22, 2011 | Nostalgia Electrics Helman Group CCP-509...
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
How do you use the Poppery II it is an older model
The Poppery II is a dry-popper - in other words, no oil. First make sure that the well is clear of the debris of past use: with a clean cloth, wipe the inside of the well, travelling in the same direction as the air fins to prevent lodging foreign matter in the ducts; this removes any kernel particles which might have been left behind by previous use. Next: place the amount of popcorn you wish to pop in the well, put the lid on, and place a large bowl in front of the lid shute. If you wish to melt butter, place 2 tbsp in the shallow cup that fits in the top of the lid (never over-fill or it will overflow into the well and make a terrible mess). Finally, when everything is set, put the plug in an outlet and be prepared to turn the bowl when the popcorn begins piling in. When there are no more fluffs popping out the shute, unplug, clean up and enjoy a great treat. Pour the melted butter over the fluffs while tossing them to make sure there is fairly even distribution and flavours and seasoning to suit yourself. A 1/2 cup of kernels takes about 2 minutes and will make about 5 cups of popped corn.
Feb 22, 2011 | West Bend 82602 Poppery II Popcorn Maker
How to use popcorn maker, no directions.
Generally you want a 3 to 1 ratio of popcorn to oil (for example, 1 cup corn to one third cup oil). The oil is what transfers the heat to the kernels to make them pop. The batch of corn should pop in about three minutes. If it takes longer, then put less corn and oil in and vice versa.
Feb 10, 2011 | Kitchen Appliances - Others
I have a presto hot air corn popper and can't remember how to use it, particularly hot much corn to put into the popper. The model number is 01/pni. Could you please help me as soon as possible, as I...
Does your popper have a butter melting cup at the top? (The one we had years ago did.) Remove that cup from the popper and fill it with the unpopped kernels. (Fill loosely to level with the rim of the cup or less. Do not pack the kernels into the cup or overfill.) Then pour the kernels into the poppiing chamber. There should also be a fill line inside the popping chamber that indicates the maximum amount of popcorn to put in the chamber. Then put the measuring cup/butter melter back on the top of the popper.
The manual for the current Presto Hot Air Popper is available as a PDF from the Presto site. The list of all their popcorn makers is here: http://www.gopresto.com/products/products_search.php?search_value=37&operation=Search&search_type=category . To find the manual click on the hot air popper and scroll down, the user's guide is listed under the parts/accessories available for sale. The current one looks identical to the one that my family had ~20 years ago.
I hope this helps.
Dec 21, 2010 | Presto Kitchen Appliances - Others
I purchased a nordic microwave popcorn maker and misplaced the directions for making the popcorn. I need to know how much popcorn to put in the bowl and amount of oil if any is to be used. I would...
The Nordicware Popcorn Popper is one that actually works in the microwave. The 3-Qt. Popper makes light and fluffy popcorn in about 4 minutes. Just place 1/2-cup of popcorn kernels in the bottom bowl and cover with the lid. No oil needed, makes up to 12 cups of popped corn. Good luck Richard
Nov 14, 2010 | Vacuums
Cuisinart popcorn popper directions
If you are using the Cuisinart pop corn poppper, don't use olive oil. Use vegetable oil. Two teaspoons is enough with 1/3 cup of premium kernels. That is it. Turn on the machine and wait til it stops popping. I LOVE my new pop corn popper. I will not do the hot air one again. I always had kernels flying all over my kitchen and popped popcorn everywhere, The Cuisinart popper is the best....
Apr 10, 2009 | Cuisinart PartyPop Maker Popcorn Maker
How much oil and popcorn do you need in the popper
single layer of popcorn on bottom of entire maker...no oil is needed but you can use a tablespoon if you like...butter melts through the hokes in lid....Place butter pats over top holes in lid before popping starts if you want butter to drip down on the corn ( it does pop better with a little oil!)
Dec 09, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Toastmaster TPC2 Popcorn Maker Logo
153 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
