Question about Kenmore 24 in. 17512 Built-in Dishwasher
Water fills but don't wash, just humms
    Genius:
  • 1,239 Answers
Hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Oct 12, 2008
Water and draining ok, washing not.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 03, 2010 | Kenmore 16522 Built-in Dishwasher
Dishwasher does not fill
Double check that your water supply line is not kinked.
This sounds like a bad fill valve. If you have hard water and most everyone does after a few years the valve will quit working properly and will fail in one of 2 ways a slow or no fill or it will not shut off completely.
I hope this helps if I can help with anything else please let me know.
Apr 15, 2010 | Kenmore 24 in. 16003 Built-in Dishwasher
Fills with water and then just humms, no spray/wash action
Hello-   The 'hum' is the motor trying to turn. If the dishwasher has been getting louder recently, then the motor bearing has failed.  The solution for this problem is to replace the motor.  Occasionally the sump gets clogged, but this rarely stops the motor.  The motor is about 125$, and is easy to replace if you can remove and re-install a dishwasher.                       Please acknowledge this posted solution. Thanks- Ed
Mar 29, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher fills with water, then drains. Doesn't wash.
HI, this is a control fault that may be solved by unplugging the unit for 3 minutes. if this reset doesn't work and, the unit continues to fill and dump, i will then recommend to replace the failed control board.
Jun 17, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
Kenmore Elite Dishwasher
I have the same problem...did you ever get an answer on how to repair
Apr 07, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore 24 in. 17512 Built-in Dishwasher Logo
179 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
