Question about LG DLE3777 Electric Dryer
Dryer stops and won't start again
I cleaned my filter but forgot to put it back in and started dryerd, about 15 minutes later, I saw dryer stopped and realized that I forgot to put filter in, however dryer won't start any more after i placed filter back and cleaned senseors.
please help!
  • 1 more comment
  • luolihong200 Oct 12, 2008
    Thank you for your post but I'm talking about dryer, the full description is as below:
    my dryer is a LG DLE3733W model, serial number: 704KWFN03075.
    I just used it for little bit over 1 year,however the problem ocurred when I was using it today.
    I load the dryer, took the filter out to clean, but forgot to put it back in and started the dryer, dryer stopped after running about 15 minutes, of course I realized the problem and immediately put the filter back in but the dryer won't start to run again.
    Called LG service center, was advised the sensors might to be cleaned, but it still won't work after cleanning the senors...
  • Oreshans Mar 21, 2009
    We have diagnositc codes 1U:00 and 18:E8 This dryer is only 13 months old too.
  • 3degreedp Apr 03, 2009
    After owning the LG DLE3777w for a year, I had an issue with it.  Everything illuminates when pushing the power button.  When pushing the start button - nothing, it does not start, it simply has a humming noise and you can almost hear a timer ticking.
    Called for service - they had me unplug for 15 seconds, push the start button for 5 seconds and whalah, the dryer started working again.  Of course, they didn't make note of the problem and that I called.
    Now I am experiencing the same thing after 2 years of owning the dryer, however, when I do all of these things listed above, nothing happens. I called into LG, and they gave me the name of a service company.
    Seems awfully weird to me that simply unplugging it could make it work again, however, it doesn't seem to be working for me this time. Anyone else have any helpful hints?
    Genius:
  • 1,239 Answers
Hi
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Posted on Oct 12, 2008
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
My dryer will run until have to stop it then it will not start the cycle
will it start an hour later? then bad motor windings
Aug 02, 2014 | Kenmore Dryers
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Coils keeps icing over
there is a disk that is attached to your coil, it controls the defrost timer in your fridge. that might be a problem or you might need a new defrost timer. hope this helps put you on the right track
Feb 10, 2013 | Amana 25.8 cu. ft. Side-by-Side...
LG2701V stopped working after lint trap was not in place
Pull the dry out and clean (UNPLUG IT FIRST) out the entire exhaust vent system..
Sep 20, 2017 | LG DLE2701 Electric Dryer
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Apr 22, 2010 | Kenmore 62602 Electric Dryer
Dryer stops after about 10 minutes. can be re-started but stops again and again. Thermostat was replaced about two months ago.
the motor could be overheating,you might need a clean out on the dryer?vac out the inside where the motor is,clean out the duct where the lint filter slides into and then go outside and make sure the air is blowing out with force,i've been finding alot of cages outside that stop animals from crawling into the vent line but the cage also catches lint and stops the air flow,if so take the cage off or clean it every month,if you have a long run blow out the vent line with a leaf blower,you could also have a bad motor
Jan 19, 2010 | Dryers
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
LG DLE3777 Electric Dryer Logo
186 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
