Actiontec GT701WG Router supplied by verizon with no instructions, any ideas
  • 4 Answers
Here's a link to the Actiontec support site : http://www.actiontec.com/support/category.php?fid=6
I believe the model that Verizon deployed is not the 701WG, but the 704WG... the way you can tell the difference is either by the number of Ethernet ports (1 port = 701WG, 4 ports = 704WG), or by looking at the label on the bottom of the device.
If you're looking for an upgrade, you should check out http://www.bestbuy.com/site/olspage.jsp?skuId=8661655&st=actiontec&lp=10&type=product&cp=1&id=1198888971179
Enjoy
Posted on Oct 13, 2008
Tip
I went to the actiontec router utility website. There is no item Beacon setting...
To boost up the performance of the wireless connection try the following.
  • Open the setup page of the Router / Modem.
  • Click Wireless and under wireless click Advanced Wireless Settings.
  • In there, change the Beacon Interval to 50.
  • Change the Fragmentation Threshold to 2304.
  • And change the RTS Threshold to 2304.
  • Save the settings. Turn OFF the router. Turn it back ON after 20 seconds.
  • It'll work.
More information on Wireless Security, click here.
For updated information on firmwares, click here.
Courtesy : http://linksysfirmwares.googlepages.com
on Feb 16, 2009 | Linksys Wireless-G WRT54G Router
Can I upgrade the antenna on my actiontec gt701wg router?
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Aug 01, 2012 | Actiontec GT701WG Router (actiongt701wg)
I have an actiontec router and cant set my nat type to open. If i turn off nat i cant get on xbox live. It says in the actiontec website for my router that i have to do something with port forwarding to...
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is enabled
Aug 09, 2010 | Actiontec (GT701WG) Wireless Router
USB port on Actiontec for shared printer?
There is supposedly a firmware upgrade available that extends the functions of the usb port so the short answer is "maybe"
My best suggestion is to check out the actiontek web site. Also you should try access the setting page (http://192.168.1.1) and see what options are available within the router itself for USB
http://support.actiontec.com/doc_files/MI424WR_Rev._ACD_User_Manual_4.0.16.1.56.0.10.11.3_v6.pdf
Is the user manual
Aug 07, 2009 | Actiontec GT701WG Router (actiongt701wg)
Use a Qwest Actiontec GT701-WG router with a different ISP?
Yes, if the other isp is also providing dsl services, but you will have to configure the device the other isp will not help you with that.
but its really not that difficult.
Feb 22, 2009 | Actiontec GT701WG Router (actiongt701wg)
Connecting printer to Actiontec GT704WG
Well the printer will have to have a eathernet plug on it to make it a networked printer and when you install it you will tell it through the network. I hope this would help you out. Do not for get to rate this solusion.
Jan 04, 2009 | Actiontec (GT701WG) Wireless Router
Connecting printer to Actiontec WG704WG
Yes it cn as long as the printer has an eathernet port on it. You would then need to install it through the network when seting it up on both computers. I hope this helps you. Also do not for get to vote for this solusion.
Actiontec GT701WG ROUTER
If you cannot connect to the router through 192.168.0.1, do a harware reset - I think there is a button in bach and use the factory default user/password. Then just disable the wireless in setup, advanced, wirless settigs - click Wireless Off radio button. And change the password.
Jan 30, 2008 | Actiontec GT701WG Router (actiongt701wg)
Computers & Internet Logo
David Payne
David Payne
