Question about Cameras
Lens error code R740-033 on an HP R742 camera. Lenn will not close I have the same problem that my lens won't close and screen only shows Lens Error Code R740-033 It tells me to go to hp.com to get the fix, but when i do, it just tells me to ring a number in the U.S. Can you tell me how to fix it, please? The camera is a HP Photosmart R742, by the way
  • Cameras Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Oct 12, 2008
WELL,
May be it was out of a fluke or something, or i hit the right point.
from the link someone gave http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html, there are 7 Steps :
I followed and as the Camera was anyways out of warranty and nothing worst can happen than break the lense, I press firmly couple of times on the lense while pressing on/off button repeatedly, at one point, it clicked and started working.
Posted on Apr 09, 2009
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
Lens won't retract
You will need to send it back in to the manufacturer to fix. If you are not too late you might get it for free or a cost of about $20.
Otherwise sometimes they might replace it with a refurbished one (which is fine) for a cost of about $50 or so.
Oct 01, 2012 | HP Photosmart R742 Digital Camera
I have a hp photosmart r742 digital camera,when i try to take picture it says lens error r740-033. What should I do?
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Aug 11, 2010 | HP Photosmart R742 Digital Camera
Lens error
If the lens makes griding sound when trying to extend, the lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 08, 2010 | HP Photosmart R742 Digital Camera
I have a HP photsmart R742, when I put the battery in it says lens error, report code R740-033. How do I fix this?
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 29, 2009 | HP Photosmart R727 Digital Camera
HP Photosmart R742 Lens error report code R740-033
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 19, 2009 | HP Photosmart R727 Digital Camera
When i turn my camera on they say lens error according to them i turned it off so i can turn it on once more but i still can't take picture.
Apr 20, 2009 | HP Photosmart R742 7.0 Megapixel Digital...
Hi, Hp photosmart r742 lens error code R740-022 . Can you help?
i have a hp 7.0 mp photosmart digital camera and when i turn it off the lens gets stuck half way and it gives me a message to look up code r740-022 can you help please thanks.
Sep 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Hp photosmart r742-lens error
Press the lens till the little doors close but not at all, i just fix it these ways 2 min ago! I SWEAR, just press it with a little hard and cross ur finger =D it work for me!
Aug 14, 2008 | HP Photosmart R727 Digital Camera
Cameras Logo
562 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
