Question about Philips 20PT6441 20" TV
Each time it powers up, but screen is all static and no sound, after while screen has fine picture and I watch it and hear it, seemingly works fine unless it is turned off and turned on again it happens all over again. Sound come in at same time picture comes in.
    Master:
  • 505 Answers
CTV's PSIP seems to be somewhat "bad", in that quite a few devices have or have had problems with it.
Please contact Bestbuy. They have the option to send a technican at your place. You can also contact the manufacturer.
Thanks
Posted on Oct 13, 2008
    Genius:
  • 1,550 Answers
  • Check the condition of fuse is .
  • This problem relates to the tuner assembly.
  • Check the circuit board and look for cold solder joints or cracks in the solder, everything still good need to take in for service.
  • 535 Answers
I think u have problem in TV has sold solder joints in circuit board.
You need to check and resold cold solder joint if you know how to repair tv.
    Scholar:
  • 136 Answers
Unplug the tv from main power outlet.remove all the external device connected to the tv.and after 10 minutes plug the power wire of the tv.and check it without connecting any other external device.
thanks.
  • ready2helpu Oct 13, 2008
    if the problem does get solve after that.that means there is a problem on the main power supply board of the tv.you have to check for any loose soldering joints.or any burned or bulged capacitors on the power supply board.
    if dont have any technical knowledge its advisable to take it to the repair center.
    as the cost will be negligible and it is worth fixing this unit.this is a common problem faced by many clients.and it gets easily repaired.
    thanks.
  • 10,594 Answers
  • Shahid Electronics
    Shahid Electronics Oct 13, 2008
    Cold solder joints possibly in power supply and H/V deflection stages near fly back transformer.
    Please mention chassis number of your tv to help you with more details or paste circuit board picture here.
My 29 inch crt has sound but no picture
Sounds like a high voltage power supply problem. With the TV on, check to see if CRT has a static charge on face of screen by placing back side of hand in front of it and feel for static charge. Also you could hold a piece of tissue paper in front of the screen to see if static electricity from the CRT attracts it. If no static charge is present, the problem is more than likely in the high voltage power supply. Unless it is something simple, like a loose connection, it would probably be cheaper to replace the TV. Do not probe around in the HV power supply while the TV is on--it could prove deadly.
Dave W.
Sep 14, 2012 | Samsung CW29M64NS 29" TV
The screen is black. I have sound but no picture.
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
Jun 01, 2010 | Televison & Video
Sound but no picture
Good luck...
May 29, 2010 | Toshiba MD14FP1 14 in. TV/DVD Combo
From a cold start,power on,screen is all blue with "no signal" in the upper right corner. while still in blue screen mode approx 2 minutes after start a squealing sound starts. about 1 minute later the...
Sounds like a power supply fault due to leaky capacitors(electrolitics).
From cold take the back off and run a hair dryer over the power supply for a few minutes then switch on,if it comes up fully working then you have to isolate the faulty part/parts and replace.
Oct 01, 2009 | Polaroid FLM-3732 Television
Unit quits after 10 minutes/ screen black and static- noaudio files on card
I call this a problem with a capcitor inside the unit has leaked or has bulged.. Witch is not provding the power it needs to function properly see www.badcaps.com just for a example what are bad capcitors.
May 24, 2009 | Astar PD-3015 Portable DVD Player
Weird lines when Playstation turns on
are you getting proper power up ...sound etc...no picture??
Dec 20, 2007 | Sony PlayStation® 3 (60 GB) Console
No picture No Sound?? Tube is fine....
Hello MagillaG, You are getting off cheap considering that this hum may be from the IHVT, hopefully the hum is not for that component. Since you have no picture and no sound that denotes a power supply probme which can be anything from a blown fuse to a bad IHVT or the horizontal output transistor. $180.00 is about right.
Sep 20, 2007 | Toshiba 27AF42 27" TV
SOUND NO PICTURE
Hello, You have a high voltage section problem I would not suggest fixing this set on your own. You will need to take this set to the shop. Because there are no user repairable parts inside of the set.
Sep 10, 2007 | Sony KV-36XBR400 36" TV
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
Philips 20PT6441 20" TV Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
