Question about Magellan Maestro 4040 GPS Receiver
Won't turn on
I am not able to turn GPS unit on. It will go on once in a while but most of the time it won't go on at all. I am using the switch on the top, plugged in to electrical outlet and not plugged in. Nothing works. Unit is only about a year old.
    President:
  • 1,111 Answers
This is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050
most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...
to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Posted on Jun 12, 2009
My Garmin Nuvi 265W Won't turn on
Lets put the battery issue aside for the moment. A Nuvi should power up as soon as the charger is plugged into it. It will turn on even if the battery has been removed. Of course, once you remove the charger, the unit will die immediately because the battery has been removed.
The first thing I would suggest doing is trying a reset. There are 2 ways to reset a Nuvi 2xx or 2xxW.
On some units (earlier versions), there is a flap on the bottom of the unit that you press in momentarily to reset the unit. There will be a label on the bottom with the units serial number and the word "reset" on the label.
The other method (newer versions) is to slide the on/off power switch to the left and hold it for at least 10 seconds.
Another common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
More information can be found here:
http://www.sharc.net/discus/messages/6/313.html?1338221806
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
Mar 26, 2013 | Garmin nuvi 265 Car GPS Receiver
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
For some reason, my Garmin 200w will not turn on at all. It doesn't matter if i have it plugged in to my car charger or on the battery, it won't turn on. Is there a quick fix, or is it time to buy...
Have you tried resetting your 200W?
Nuvi 2xx & 2xxW: There are (2) different versions of this series.
Some will have the reset on the bottom, where the decal is. There will be a small flap labeled "reset".
On newer units, slide the On/off power switch to the left and hold for at least 8 seconds and then release.
Let me know if this worked for you.
Jun 28, 2011 | Garmin nuvi 200W GPS Receiver
Garnin 260w slide switch will not turn off unit.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 01, 2010 | Garmin nuvi 205 GPS Receiver
Try to power up my GPS 60csx and the screen stays on for several seconds then fades out.
I would suggest that you try the following master reset and software
update.
Please be aware that if you have not used your gps for a while it will
take time to download fresh information.
With the unit switched off please press and hold QUIT + MENU + ZOOM OUT
+ POWER
You will lose any data stored on the unit so back your unit up first. I
would also suggest running the latest software update from the following
link, if you have not already done so http://www.garmin.com/support/download.jsp
Once all this is done please leave your unit with a clear view of the
sky and allow it to acquire a satellite fix. This may take time so
please be patient. Once you have a fix leave the unit for a further 40
minute to achieve a good almanac update.
Jun 28, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Turn off garmin
I just find it unbelievable that there is no off button on this watch. I dont want to use it as an everyday watch..its too big and ugly for that.Also you have to remember to turn off the gps as it will drain the watch overnight.You have to switch the gps on every time you do a run. I simple on and off button is all that is needed.It is just a matter of turning it on when you go for a run and you are ready to go. Same with all 'latest ' products..they give you the improvement over the last model but give you a downside...which will probably be corrected on the next incarnation....very clever marketing.!
Feb 03, 2009 | Garmin Forerunner 405 Handheld GPS...
Zumo 550
Make sure that the bike's electrical connection to the GPS unit is actualy not having power once you turn the key off in the bike. This GPS turns on with external power. It is inherent in to its design.
In the case were you cannot have the bike's power source to the GPS turn off with the key, see if you can wire a small in-line switch in series with the GPS unit so that you have an external power switch. This should be easy to do.
The models I have used from Garmin have their own power switch. You should be able to use its power switch to turn it off.
Jerry G.
Jul 19, 2008 | Garmin zumo 550 GPS Receiver
Doesnt switch off
I have the exact problem. I was just backing up the unit. Computer does not recognize it. won"t turn off or on. grey screen.
Dec 12, 2006 | Tomtom "GO" GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
93 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
