Zenith C27A24T 27" TV Logo
Posted on Oct 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zenith System 3 Model # SR2571DT
When the tv is on from a cold start, the picture is fine, but the longer it is on, the darker the picture gets. This was a gift and I don't know how much it costs to replace it or if it's even worth the trouble. Could you please help?
Thanking you in advance, SqueekieT
Anonymous
Level 2:
Champion:
  • Expert 252 Answers
  • Posted on Oct 16, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
252
Questions
0
Helped
51525
Points
392
If you know how to solder , then resolder your tv ,maybe your tv had a lose connection.
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ; shopjimmy.com
Picture keeps getting darker
Most likely will need a new lamp soon. your tv uses model # 6912B22010A
2answers
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
I have a 52" zenith plasma tv and it has gone black and fades into a vague darker picture after a while.....everything is fine accept for the pic
the ICs or the capacitors on the main board of the tv which controls the picture quality of the tv.is either gone loose and needs resoldering.or it is going through its last phase so further problem can occur if it gets completely faulty.get it replaced before it gets completely faulty.to avoid the further problems.
Picture Fades
The more you play set the longer it will last, it sounds like you may have poor connections, cold solder joints try soldering around flyback transformer.
NO PICTURE...BUT SOUND
Your HV circuit is defective. Most likely horizontal output transistor is shorted and you may need to replace the flyback. You need to call an expert.
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
