Question about E-Machines eMachines Desktop PC
Emachines model 780 monitor comes on for one second then goes blank
Any idea what i can do to fix my monitor? when turned on, it flashes on (shows opening pc screen) then goes blank (black) no picture.
  • axewiz77 Oct 28, 2008
    eMachines model 780 monitor: It comes on for one second then goes blank. I even tried the monitor with a different pc. If you turn it off and on again, it will do the same thing, blink on then off again.
  • magickittie Jan 19, 2009
    the monitor is the problem
I have a Similar issue with an emachines monitor..after trying a few things such as trying it on a different computer...changing cables and changing power cords..also turned the brightness up all the way...you can faintly see the windows screen on the monitor. I have determined there is a fault within the electronics of the Monitor Itself...if you have this problem then there is most likely your answer. Use another monitor and hook up to your PC in question..if it works then you know its the other Monitor. Hope this helps
Posted on Nov 25, 2012
  • 4 Answers
Change your power adaptor
Posted on Aug 30, 2010
  • E-Machines Master
  • 998 Answers
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Posted on Oct 16, 2008
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 15, 2011 | HP Compaq WF1907 Monitor
When I turn my computer/monitor on the monitor has a picture for about 3 to 5 seconds and goes blank. I can turn it off and back on, but the same thing happens.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 01, 2010 | E-Machines eMachines Monitor E15T4
Screen goes blank after 5 seconds switching on
The picture board on your monitor is bad, since it goes blank after five seconds, it shows that the picture board of your monitor has developed fault.
Take care.
Apr 25, 2010 | Proview PX 780 Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
I have a Soyo Monitor, Model MT-NI-DYLM1998. It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect. The Soyo monitor stays blank (black) except when it is turned...
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Soyo DYLM1998 Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
E-Machines eMachines Desktop PC Logo
722 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
