Question about JVC FS-SD1000 CD Shelf System
Blown Amp AC?
I have a JVC FS-SD1000 which was purchase about 6 years ago. After about a year my subwoofer quit on me and simply would not work. I took the sub to HH Gregg where I originally purchased this system and they diagnosed the sub. After the diagnosis, the tech advised me the sub had a blown amp ac and needed to be repaired which at that time would have cost $150. Any ideas on how to save some money to have an "amp ac" fixed or any do-it-yourself recommendations? Thanks
IZ
  • Anonymous Dec 13, 2008
    Same thing. My subwoofer turns on and the light goes from red to green when I turn the system, but nothing comes out of the subwoofer. I guess I have the same problem as yours. Thanks for any help.
    Novelist:
  • 124 Answers
Unfortunately, these older systems lose value rapidly and the cost of repairing problems like this can end up being as much as buying another system! Actually, you might be surprised to learn that JVC Service still sells many accessories and components from older systems. You can buy this sub woofer for less than $100, which should easily beat any repair cost you'll face. It may even come with the satellite speakers. The part number is VSDT2000R-SPBOX .
NOTE: JVC Service has a free shipping coupon going on right now, so you'd want to use that: DZYZXFX49GYZZ81
Also remember that there's a standard connection between the head unit and OEM sub woofer, so you're free to use a non-JVC unit. I would try to find one with a comparable power rating. Of course, the only drawback is that it won't blend in with the unit... but then, the sub woofer is usually tucked away out of sight.
Posted on Dec 24, 2008
  • Gary
    Gary Dec 24, 2008
    One more thing -- before you order anything PLEASE verify with JVC Service that the part I've listed does indeed include the sub woofer. Their website is not very descriptive of the accessories/parts.
Hi i purchased the bnps102 woofers and used them for 2 weeks i really enjoyed them and i also purchased the pyle 1400 watt amp and a jvc deck along with the boss amp kit installation now the speakers about...
If the lights on your sub box aren't coming on it's either your ground of power wire came loose or the transformer blew. As for the subs, make sure all the connections are good, especially on your RCA wires. If your amp is getting power, then check your speaker connections. Also, make sure to turn the gain know up. The gain knob is located next to the RCA input on the amp. Let me know if this helps.
Aug 21, 2011 | Pyramid BNPS102 Car Subwoofer
Subwoofer clicks and quits
The power amp that drives the subwoofer has quit. This will require repair. It is likely that the replacement you got from Ebay was defective as well. Not un-expected as I get stuff to repair from there all the time.
Your original unit failed in a manner to shut down the power supply. The replacement has a good power supply but a only fried sub amp.
Aug 10, 2009 | JVC TH-M606 System
Subwoofer pushing out problem
it sounds like one channel in your amp had shorted and letting dc go to the speaker...a speaker is an electromagnet and requires ac to make it pulse..the amp has a blown channel and would have to be repaired and a factory service center...there is no quick fix..
May 27, 2009 | Lightning Audio B1.10.4 Car Subwoofer
My amplifier stopped working? Why?
either smell your amp and see if it could have blown or the place that installed your deck didnt hook up your rca jacks
Mar 29, 2009 | DB Drive Speed A600 Car Audio Amplifier
How can we turn off the automatic start of Radio or CD setting?
The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
If you have lost your manual, you can download another one for free from this location:
http://www.retrevo.com/s/JVC+SD1000
Nov 17, 2008 | JVC FS-SD1000 CD Shelf System
CD player shuts itself off as soon as you turn it on
I had the same problem. The F1001 fuse was blown, it is a 1.6 amp, 125 volt fuse, GMA type.
Dec 09, 2007 | JVC FS-S57 CD Shelf System
Infinity PS-10 quit working
I think the electronics have a 3 years warranty and the drivers have a five years warranty for this product, maybe you can have it replaced. Maybe the auto on/off signal detector is the culprit.
Dec 09, 2007 | Infinity PS-10 Subwoofer
JVC FS-SD1000 Shelf system
where are you located?
craig:)
Oct 06, 2007 | JVC FS-SD1000 CD Shelf System
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
JVC FS-SD1000 CD Shelf System Logo
178 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
