Question about Vtech V.Smile Pocket
Screen is blank and there is no sound
My kids got there v smile pockets for Christmas 07 and they only worked for one month. The screen is blank and there isn't any sound. I changed the batteries and got the same results. So I bought the charger for the v tech games and still no difference. The off and on button wont work either. I need to know if there is another troubleshooting besides pushing the off button, removing the power source and replacing them and pushing the on button. Remember my off and on buttons don't work.
Thanks.
    Problem Solver:
  • 8 Answers
Try pressing the reset button on the back.
Also, try cleaning the contacts on the games. Push back the sleeve on the game and clean good with alcohol. If this doesn't do it, unplug it, and clean the contacts inside the unit with a qtip.
Hope this helps!
Posted on Dec 10, 2008
My daughters v. smile will not turn on
The ac adaptor has to be set to the correct voltage , there should be a small adjuster on the mains plug.
1.5v for each battery ( regardless of battery size ); so 6v for a 4 battery , 9v for 6 battery , etc.
Oct 15, 2009 | Vtech V.Smile TV Learning System (Pink)
V tech pocket smile
Hi i'm Ryan, my daughters did the same thing, I removed the battery cover and there is a small pin hole with a reset button in it, try resetting it. I did and it came back on and works fine.
Dec 29, 2008 | Vtech V.Smile Pocket
V-Tech Cyber Pocket Screen will not work
Hi i'm Ryan, have you tried to reset it? Remove the battery cover there should be a small pin hole with a button in it, push it to reset. It worked on my daughters.
My daughter v smile pocket does not work
Sounds like the contacts on the games need to be cleaned. On the game cartridge, push back the little cover and clean the gold colored contacts on both sides. I use a cotton ball or q-tip with alcohol on it. Let it dry before you put it back in the v.smile.
Dec 09, 2008 | Vtech V.Smile Pocket Pink Electronic...
Vsmile pocket - sound OK but blank TV screen when using with TV
Make sure that the yellow is on the same port as the white. also, make sure the yellow port is not labelled OUT or OUTPUT.
Nov 13, 2008 | Vtech V.Smile TV Learning System
Screen is blank
Try the reset button on the back of the unit.
Also try cleaning the contacts on the games. Push back the sleeve on the game and clean good with alcohol. If this doesn't do it, unplug it, and clean the contacts inside the unit with a qtip.
Hope this helps!
Nov 07, 2008 | Vtech V.Smile Pocket
V smile pocket
Get an adult male to check jack and see if something was jammed inside, next open it up with screwdriver to see if anything is loose or contact manufacturer since warranty is usually a yr.
V-SMILE POCKET LEARNING SYSTEM
sounds like you need those lithium battery's . ask for them at wal-mart in electronics or at radio shack .
Jul 09, 2008 | Vtech V.Smile Pocket
V.smile screen won't work
yes take the cord to radio shack. you will find your cord there. you may have to buy all three cords but not very costly. tell them there is a short in your wire. need help finding a radio shack go to www.radioshack.com and click on the store locater tab.
Jun 05, 2008 | Vtech V.Smile Pocket
Polaroid i733, purple picture
I got this camera or christmas .Worked good for awhile. Screen went purple and now its not working.
Apr 03, 2008 | Polaroid i733LP Digital Camera
Vtech V.Smile Pocket Logo
461 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
