Question about Hayward 250kbtu Ng Pool Heater - Inground
POO; HEATER DRAIN HAY WARD G AS HEATER
D R AIN HEAYWARD GAS HEATER
  • 11 Answers
Are you asking how to drain it? If so some older models come with a drain **** located on the bottom side of the black manifold. It is brass. You can loosen the drain **** and the water will drain out, be careful when tightening the drain **** back up though, they can break easily. You do not have to put much torque on it at all, dont even put a tool on it at first, if it leaks, then tighten it a little more. The newer models come with a brass plug instead of a drain **** and you can remove the brass plug. Or the best way i think is to unhook both unions for the inlet and outlet on the heater, use a shop vac on blow, and blow the water out. But if you are winterizing the pool equipment, the heater is not the only thing that needs to be drained.
Posted on Jan 10, 2009
Ward Floor Heater, Model 570 EDR, works but is outputting much less heat than normal. Any information about where to look, parts I might need, etc would be greatly appreciated.
"The valve stem labeled Hot at 12 oclock and Off at 3 oclock,"
Is probably the problem. I'd try wd-40 overnight to see if it would free up the valve. It worked on a similar problem outside gas grill valve.
Mar 04, 2015 | Montgomery Ward Heating & Cooling
Montgomery Ward
you didn't specify whether it was electric or gas, so i'll assume it's gas. Clean or replace the thermocouple that the pilot light heats. Yes it could be the thermostat as well.
Nov 07, 2013 | Water Heaters
Manual for wards hot water heater
1) Copy following links to identify gas control valve, troubleshoot resources, and gas water heater installation
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Unsure which manufacture makes/made Wards water heater, or how old your unit is.
Three manufactures make most brands tank-type water heaters, and generic manual basically covers all brands.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) Add comment Feb 2013, and say what you are doing.
Feb 03, 2013 | Water Heaters
I have a Mont Ward 500 gas heat system that the blower keeps running, Im thinking it's the thermostat. If that's it, which kind should I get?
There is a pull switch on the Fan Limit Control. Check to see if it is pushed in. Pull it Out for normal operation.
Nov 13, 2010 | Montgomery Ward (223600UP) Heater
How to drain an old MW water heater. There doesn't appear to be a valve to turn.
lay it on its side with one pipe on top and the other on the bottom so it can get air and drain faster,then when almost empty turn it completely upside down to finish draining
May 29, 2010 | Montgomery Ward (223600UP) Heater
Why do I sometimes hear a loud explosion like coming from the poo heater?
That is called delayed ignition...shut it down and get it serviced before it realy goes boom!!! The ignition sequence is not working right...
heatman101
Apr 25, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
We have a old Montgomery Ward five-hundred Glass Lined hot water heater Serial # SNN 1177204708 Model # SRM33331A Type Gas NATURAL GAS PRESS IN. W.C. Input BTUH 46,000 MAX SAFE INLET 7.0 RECOVERY GPH 38.6...
I believe I had the same problem with my water heater about 15 years ago. It started with a small leak, then the tank broke flooding the room. I think it would be be best to replace the unit. Water heaters tipically have a 8-10 year life.
Mar 11, 2009 | Montgomery Ward (223600UP) Heater
Hayward 250kbtu Ng Pool Heater - Inground Logo
198 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
