Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis loud screech when it brakes the spin cycle.
I have a 3 year old atlantis and when it brakes the spin cycles it makes a loud screech noise . It hurts the ears! It's not the belt, been checked. With the front cover off you can see how the tub pivots normally to absorb the braking action. I don't think it is the lower tub mount as it seems to move back and forth with ease. Also how does the transmission function? Only a small 1/4'' hose goes to the tub adapter from the load size control at leftside. I appreciate any info. Thank you, Scott.
    Novelist:
    Champion:
  • 261 Answers
Hi Scott,
The brake has dust on it from wear. It is at the base of the machine inside the center were the base of the gear case rests. The brake is easy to fix with one catch. There is a tension spring hold it together, never mind the 5/16 hex screws attaching it, there is 200 pounds of pressure there.
Parts 16 to 23 are causing your problem. You need parts 35-2948, 21001161 and 35-2018 which are numbers 21, 22 and 23. While your there tell them you need a spring compressor for this job. Make sure after removing 24 that the compressor is fitted to the shaft and that it lines up to the notch in the shaft so your retention pin holds the spring until you can loosen the stator(23) from the brake, 22.
Posted on Oct 12, 2008
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Atlantis screeches @ end of spin cycle,
may be something stuck in the drum or a segment raised on the motor. to test either remove the belt and spin the drum if no noise then the motor is faulty. if a noise then there may be a bra wire between the drum/tub.
Mar 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
633 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
