Question about HP DeskJet 820cxi InkJet Printer
COLOR DOES NOT PRINT, NEW CARTRIGE INSTALLED
When printing any text color the print was a shade of light pink and any blue was blank. I repaced the cartrige and I don't get any color at all now. The black is normal.
  • 4 more comments
  • Firstin Oct 12, 2008
    I attempted to print a page with light purple type and it printed out a ghost of very light purple, a complete page but unreadable without bright light. The black border was perfect. The cartridge is a remanufacured by West Coast Office.
    not under waranty is not a solution.lets try again to find an answer or refund the money as advertised
    sorry do not have head cleaning utility, whats next?
  • Firstin Oct 13, 2008
    thank you for the suggestons I had already tried all of them befor and also put the old cartridge in with same results. I'm usuing a HP Pavillion dv6000 as my computer and it is suppose to have the drivers to interface with the printer. Windows Vista is the software. I don't where else to go accept just black
    The suggestion from anaaymous sounds like like very possible solution which will attempt. thank you ihope it solves the problem. will report the results firstin
    I'll try it and get back to you
    Genius:
  • 1,124 Answers
1.- Take out the new cartridge.
2. Put in a cup boiling WATER
3.- Put the print surface the cartridge over the water to receive the STEAM a couple of minutes (Make sure that do not put the cartridge into de water)
4. Reinsert the cartridge and try again
If the cartridge doesn't work, need to be replaced. Sometimes (happened several times to me) the NEW cartridges coming defectuose and doeesn't work. Simply return the cartridge to the store and ask for replace.
Posted on Oct 13, 2008
    Top Expert:
  • HP Master
  • 69,102 Answers
I have had the same problem with my old HP printer, it was the ribbon that connects the cartridge to the circuit board, it is what moves with print head as the printer prints, it is the weak link, you can replace it, contact HP web site parts dept for the Price and availability of the printer circuit ribbon.
    Sergeant:
    Champion:
  • 334 Answers
Solution #6 posted on Oct 12, 2008 COLOR DOES NOT PRINT, NEW CARTRIGE INSTALLED - 2%20stars_w.png
85e2e31.jpg mohaCOLOR DOES NOT PRINT, NEW CARTRIGE INSTALLED - wizard_s.gifbr /> Rank:wizard_s.gif Wiz
Rating: 79%, 100 votes
contact service center..if u have warranty.. THIS LAST WARING MOHAMMED DONT ANSER ?S U DONT KNOW WHAT U ARE DOING IN THIS IS YOUR LAST WARING THX FIX-YA
Posted on Oct 12, 2008
  • nick helpap
    nick helpap Oct 12, 2008
    MAKE SURE IN PRINTER OPTIOBN MENU YOUR NOT CHeaking the box that says printer coler in black only ok in printer option in control panel cheak that 1st thx nick also download latest driver form makers website www.hp.com under help suport area type model in then xp or vista then save new drive rto hard drive sumware then intslal over old or remove old driver then install new updated one that fixes alot this stuff thx nick
    Novelist:
  • 159 Answers
Take out the cartridge. Let it sit on a papertowel soaked in warm water for 5-10 minutes.
If the 3 colors are in there they will show on the towel.
If one or two colors do not show then the jets are clogged.
If you get all colors. Wipe the contacts on the cartrige clean of possible old ink and the cartrridge carrier too.
Put it in the unit, and try to print a heavily colored page in high quality. This should free up the cartridge.
Fran
  • Fran Bednar
    Fran Bednar Oct 12, 2008
    PS: the clean cartridge feature should be here:
    Start -settings-printers- right click on your printer- go to properties then look for services.
    Fran
    Sergeant:
  • 352 Answers
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
    Sergeant:
    Champion:
  • 200 Answers
Hi
Well.. I would check the followiing:
1) did you take off all the little tabs, etc from the new ink cartridges?
2) are all the cartridges in teh correct spot? Sometimes having one off will force the others to not go
3) are all the cartridges seated correctly? Try removing them and putting them all back in
4) try turning the printer and PC on/off..
5) check the driver.
6) remove cartridge and clean the head and seated the cartridge and then check it.
thank you
  • HP Master
  • 1,879 Answers
Use the Printer Head Cleaning Utility
    President:
  • 1,952 Answers
Contact service center..if u have warranty..
  • 10,594 Answers
Have you replaced genuine ink cartridge or refurbished or compatible?
  • Shahid Electronics
    Shahid Electronics Oct 12, 2008
    Always use genuine ink cartridge. Re manufactured, refurbished doesn't work good.
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
I bought new ink black and color but i try to print in pink and i can't how can i print in pink
Hi alexgallo01
Do you get other colours except pink?
If that is the case,reasons could be:
1. there is not enough RED or BLUE in the cartridge.
2. you haven't selected pink colour on the text or images you are trying to print.
If you are typing a document highlight the text you want in pink, and choose PINK color for the font.
Then print the document. The printer will use color closest to your choice, if it does not have the exact color.
Hope this will help.
If it help you, please give a rating
Cheers
luciana44
Sep 14, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Color now is pink, does this mean I should repace cartridge @HP D4160
yeah replace the color cartridge, first allign the cartridge if problem presists then change it
Oct 31, 2008 | HP OfficeJet 6210 All-In-One InkJet...
COLOR PRINTING CANNON PIXMA 3000
yes you need a saringe with some nail varnish remover init then remove cartriges then inject nail varnish in the printer jets you can tell if there blocked as it will hard to squirt in but keep going till it easy to do then you will no it clear then just put a blank sheet of paper in it and run it after you have cleaned the exses up of course
Feb 23, 2008 | Office Equipment & Supplies
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Everything printing in PINK
Assuming you have successfully eliminated cartridge/print head problems, the only other thing to try is to delete the printer software and reinstall [Start/Printers and faxes -right click on the printer icon click delete- install new printer -Have the software disk and handy or select from list- select maker, select model,] I suspect the problem is still print head/cartridge however
May 11, 2007 | HP OfficeJet t45 All-In-One InkJet Printer
HP DeskJet 820cxi InkJet Printer Logo
176 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
