-   i have same probloem wid my sony RW DRU-V200A
how to solve it Windows cannot load the device driver for DVD/CD-ROM drives. The driver may be corrupted or missing. (Code 39)" problem, and notify you when a new solution is offered. -   Guest
Mar 20, 2009
-   Same Problem my drive is PIONEER DVD-RW DVR-112D
-   Guest
Mar 16, 2009
-   I have the same issue for both of my drives. One is an HP DVD-RW and the other is an HL-DT-ST-CD-RW. I am running Windows XP.-   geckodude
Mar 11, 2009
-   i try to use my dvd burner i get the same error message in every way does this mean i will have to have hard drive wiped and reset
-   texasfeeler
Mar 11, 2009
-   EXACTLY AS STATED ABOVE
-   texasfeeler
When I burn a music disk using Nero the burn compleats ok but some of the data is missing the songs...
(More)
When I burn a music disk using Nero the burn compleats ok but some of the data is missing the songs have words missing, but the songs play ok if played direct from my music folder( so i know they have ripped ok) I'm using verbatim media and the firmware is 104c and ive tried using a slow burn speed with no luck.
i have the same problem dvd drive will not load vista tells me corrupted or not missing. tryed different spyware to fix . what in the system registry do i need to look for and edit to repair my driver. thank you for any help
