Question about Kitchen Appliances - Others
Don Gilbert Insect Light Trap/Bug Zapper
Model 220 Guerrilla, How Can I Bench Test This Item? Do Not Think That The Zapper Part Is Working. It Lights Up .. Wondering What The Grid Voltage On The Bug Grid Should be? Any Help Greatly Appreciated.
Tried To Go to Thier Website But There Was No Troubleshooting...
  • 34 Answers
SOURCE: RZ-220 Error Code P04-513
that is the ink overflow sensor.
Posted on Jul 30, 2008
  • 49 Answers
SOURCE: hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Posted on Jan 03, 2009
  • 527 Answers
SOURCE: Can't find driver for Logitech X-220 speakers
click these links for download
Link 1
Link 2
U can also install related any driver. for ex. realtek audio driver so try to install other drivers also.
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Mar 18, 2009
  • 8404 Answers
SOURCE: microwave doesn't heat
check your door safety interlock switches ...
switch burned = no circuit
no circuit = door open (as far as the oven is concerned)
door open = no magnatron action
no magnatron action = no heat
Of course it could be something else ... but if it is the switch, you can easy fix that.
Posted on Oct 09, 2009
  • 262 Answers
SOURCE: Trying to locate electrical junction to test fuel level sensor
Fuel Level Indication System The fuel level indication system is a magnetic gauge system. It consists of a magnetic fuel gauge (9280) mounted in the instrument cluster (10849) and a sending unit located in the fuel tank (9002) with an instrument cluster gauge amplifier (10E849) in series between the two. No instrument voltage regulator is used with this system. Fuel Gauge
The magnetic gauge movement consists of three primary coils, one of which is wound at a 90-degree angle to the other two. The coils form a magnetic field which varies in direction according to the variable resistance of the sender unit which is connected between two of them. A primary magnet, to which a shaft and pointer are attached, rotates to align to this primary field, resulting in pointer position. The bobbin/coil assembly is pressed into a metal housing which has two holes for dial mounting. There is no adjustment, calibration or maintenance required for these gauges. The instrument cluster amplifier is calibrated to the fuel gauge. The instrument cluster amplifier and fuel gauge must be replaced as a system. Instrument Cluster Gauge Amplifier/Check Gauge Module
The instrument cluster gauge amplifier electrically averages fuel sender readings so the fuel gauge displays actual fuel level and not fluctuations due to sloshing in fuel tank. The instrument cluster gauge amplifier is a small printed circuit board which latches into a pocket on the back of the instrument cluster. The electrical connections for ignition, ground, input from fuel sender and output to fuel gauge are made through a spring-type connector on the instrument cluster gauge amplifier to the instrument cluster printed circuit (10K843) on the instrument cluster. There are no provisions for calibration or adjustment of the instrument cluster gauge amplifier.
Fuel Sending Unit
The fuel sending unit consists of a variable screened resistor made up of a ceramic substrate. It is controlled by the action of an attached float in the fuel tank. When the fuel level is low, resistance in the sending unit is low. When the fuel level is high, the resistance in the sending unit is high. As the float moves from empty to full, the resistance will gradually and continuously increase. f9e3b50.gif
Posted on Mar 11, 2010
Should my 1.5 acre stinger bug zapper zap when I plug it up
Intuitively, I glean it zaps when you turn it on only if you are a bug. Zapping is caused by the bug encountering the zapper. Otherwise, it would zap you even if you were not a big bug, simply because you were in close proximity.
Aug 20, 2017 | Air Purifiers
I have a flowtron bk-2125 bug zapper, looking at the troubleshooting, it said check for power on the grid, how do i do that. I changed bulb and it is not coming on, it said if i have power then the starter...
If you have no power from the grid then bug zapper is not problem. If bug zapper is a corded plug in application then unplug and plug into a plug in that you know works. Check your breaker panel for a tripped breaker and reset if necessary. Or try a different appliance by plugging something that you know is operational into the same plug. If it works, there is likely an internal problem in bug zapper.
Oct 08, 2014 | Cars & Trucks
I have fruit flies and i used the vinegar trap but it still doesn't work how can i get rid of them?
Try an electric bug zapper. You can get them at any home improvement store. On line too
Oct 01, 2014 | Home
When installing the two required C batteries into my new Stinger bug zapper. In what manner should the batteries be inserted into the battery compartment ?
Not sure which model of Stinger bug zapper you have. If you are using C batteries then it could be a portable racket zapper.
Please check model number and compare with list of manuals on this site.
Owner Manuals StingerProducts com
If there are only two batteries then there are 4 ways in which these can go. You could try and see which one works.
Sep 03, 2014 | Camping, Backpacking & Hiking
How to repair
Is the buglight still working? I simply take a blade of grass and place in between the wire cages to make electrical connection and verify transducer is not defective. If you don't get a spark quickly your transducer may be burned out as I cannot keep one working due to larger insect getting in unit and overloading the transducer.
May 22, 2014 | Stinger 1 Acre Bug Zapper
I recently bought a chefmate racket bug zapper from target, but can't seem to get it going. I pressed the buttons over and over so it would make it's high pitch sound and then i would know it was...
If this is a grid type of item then something has to be touching the grid to complete the zapping circuit. What you have is basically a direct current device that has a positive charge on one grid and a negative charge on the other and only if something touches both grids will it actually zap anything. Merely pressing the button only charges the grids and does not cause arcing of electricity between them. If you want to test it find a dead bug and drop it onto the grid while pressing the button - then shake it sideways so the insect touches both sides and you will see it works.
Nov 19, 2017 | Vacuums
What the use of insects
Hi chubbychecke,
Try the following link:
Or search on a search engine like Clusty ( on the use of insects.
Oct 13, 2009 | The Learning Company Achieve! Math &...
I have a CMZ984 coleman portable rechargeable bug zapper.I have lost the manuel and charger for it.It is 4 watts.The company that made it for Coleman has gone out of business.It is about 2 years old.What...
The CMZ984 takes 6 volts DC at about 850 ma or 0.85 Amp. The problem is finding a plug that will attach to the Coleman charging port. Use the Radio Shack universal DC power supply. This is a little unit that comes with an assortment of plugs and has a number of switches on the Radio Shack DC power supply. (1)-Find a plug inside of the Universal DC power supply that fits without forcing, (2)-set the voltage to 6 volts and (3)-the polarity to "+". When the universal power supply is plugged into the bug zapper and the universal DC power supply set at 6 volts, turn on the BUG ZAPPER. If the lights inside turns on when the battery is dead then you probably have all switches set correctly. At yard sales, this UNIVERSAL power supply sells for about $1. It comes with a number of different plugs. Don't forget to write the voltage and polarity on the bottom of the bug zapper for the next time.
Jul 29, 2008 | Kitchen Ranges
Kitchen Appliances - Others Logo
237 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
