Question about Sylvania SRT2232S 32" TV
Sylvania 32inc tv
Red lines on srceen
  • Anonymous Oct 29, 2008
    I have a Sylvania 6632LG 32" flat panel. When turned on, it has vertical colored lines in various colors and widths. They slowly fade to almost gone after an hour or two, but are slowly getting worse 9wider and more of them) at start-up.
    Champion:
  • 252 Answers
Your tv have a vertical trouble, maybe the ic is busted
Posted on Oct 12, 2008
Need remote codes for the sylvania tv model 6427gg
Hello
Three digit universal remote codes for Sylvania TV are:
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
Four digit universal remote codes for Sylvania TV are:
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Jul 15, 2011 | Sylvania 6427GG 27" TV
What is the universal tv code for mitsuwa?thanks
Hello
Direct Code Entry
Jun 11, 2011 | Sylvania SRT2319 TV
Codes for the vista tv set 19inch
Hello
Three digit universal remote code for Sylvania are:
Four digit universal remote code for Sylvania are:
Direct Code Entry
OK
Jan 18, 2011 | Sylvania 6419TE 19" TV
I need the codes for universal control
Hello
Three digit Universal Remote codes fro Sylvania are:-
Four digit universal remote codes for sylvania are:-
NB: Switch OFF and switch ON your TV with its front panel power control switch each time before trying an other code.
Direct Code Entry
OK.
Jan 09, 2011 | Sylvania SRT2420P TV
I need the tv code to enter into my universal remote
Hello
Three digit universal remote codes for Sylvania are:-
002 009 109 209 309 402 408 502 508 717 807 914 917
Four digit universal remote codes for Sylvania are:-
NB: Switch OFF and switch ON the TV, with its FRONT PANEL POWER SWITCH, NOT BY THE REMOTE CONTROL HANSET; each time before trying an other code.
Direct Code Entry
OK.
Dec 29, 2010 | Sylvania 6419TC 19" TV
ONEFORALL TV CODES FOR REMOTE CONTROL \I JAVE ONE VOF ZLLTV REMOTE CONTROL. I NEED THE CODE FOR A SYLVANIA TV FOR THIS CONTROL TO WORK. CAN YOU HELPL?
Hello
Just check with these numbers.
0054, 0030, 0020, 0096 [ These codes are exclusively stated for Sylvania]. You can also try the following numbers also.
Three digit universal remote control codes for Sylvania are:-
Four digit universal remote codes for Sylvania are-
Direct Code Entry
OK.
Dec 15, 2010 | Sylvania SRT2420P TV
I want to play my xbox I have da yellow white and red wires plugged in but can't get to the video channel...I know I need a remote but which one?
You would use the Sylvania remote. It will either have a TV/Vid button or an input button. The screen will display "Video" or "Line". You can also do this from the front of the set by pressing "CH-" it will go "3", "2", "Video"
Oct 07, 2010 | Sylvania 6419TC 19" TV
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Sylvania SRT2232S 32" TV Logo
50 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Dave Naylor
Dave Naylor
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
