Question about Panasonic Lands Phones
I have a panasonic phone, intercom system. Since a recent thunderstorm, my nonsysten phone answering maching picks up when the door bell is rung. The nonsystem phone no longer has caller ID, and one must dial 9 in order to get a dial tone. Any ideas. Dan
  • 6 more comments
  • Mktdds Oct 12, 2008
    The phone answering maching is not supposed to pick up when the bell rings. The nonsystem phone should have caller ID, and one should not have to dial 9 in order to get a dial tone. All of my other panasonic system phones work fine. There must be a way to program the panasonic phone system to work with the V-tech non system phone.
    I have tried another phone all ready. It has to do with programming the panasonic phone system to work with anonsystem phone. The battery has nothing to do with the problem.
    The system is Panasonic Advanced Hybrid system KX-TA624. The nonsystem phone is a V-tech 5.8 Ghz digital spread spectrum answering machine.
    vtech phone #6773, Panasonic phone system is listed above
  • Mktdds Oct 13, 2008
    Did you give up on me? Please respond!!!!
    panasonic phone KX-T7030
  • Mktdds Oct 14, 2008
    Panasonic phone Kx-T7030
  • Mktdds Oct 16, 2008
    You guys haven't helped me whatsoever. Please do not charge my credit card because I will protest the charge. Thanks Dan
  • 2,071 Answers
Just look for the reset button,or go to menu then select factory default setting .If not have reset button just take out the power supply for 4 - 6 hours purpose is to erase the memory setting before and then put it back the power supply again if the problem still exist .
Hope it may help you;
Regards,
VOTIT
Posted on Oct 12, 2008
    Sergeant:
  • 352 Answers
This is not so much as advice as is an observation. Electrical storms and electronics don't play well together. It is my honest opinion that I believe you may have been the victim of residual trace lightning, which in a lot of ways is worse than a direct hit. This type of static charge wreak havoc on electronics, I know I lost a 55 hitachi tv a few years back. The bad news, your phones main board sounds like it is corrupted(no good). To take it to your certified repair center will cost more than the phone is worth, suggestion> new phone.
anaanymous
  • anaanymous Oct 12, 2008
    Excellent, thats even cheaper than my suggestion, lol.
    anaanymous
    Sergeant:
  • 409 Answers
the 2 systems should be separate because they are not on the same phone system. i would recommend that you get a tech out to take a look at the intercom system. when there is storm, it distrubs all electrical circuits.
can you supply me with the model # off your Panasonic phone please? i will find the use and care guide and possibly service information to help you further.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Could you please provide us the Panasonic model and the nonsystem phone brand and model numbers please?
Thanks,
    Sergeant:
  • 399 Answers
Try removing the battery of the phone which is not working .and then reinsert the battery after you check whether it is perfect.sometimes the battery gets leaked and does not get work.removing the battery and reinserting also resets the phone.and i hope it works properly as it was working before.
feel free for further queries.
thanks.
    Brigadier General:
  • 3,614 Answers
CLARIFICATION:
what exactly the complete info about your problem.?
thanks
  • 4 more comments
  • micromaster
    micromaster Oct 12, 2008
    To use VTEXH 5.8 into other phone;
    1. After charging the battery, the screen will display:
    2. Press SEL, you will see ENTER BASE ID, if the
    screen already says ENTER BASE ID, go to step 3.
    3. Enter the 15 digit base unit ID code, located on the
    underside of your mi 6820. If you make a mistake,
    press the DELETE key to backspace (delete characters),
    then enter the correct information.
    4. Press SEL to complete the registration process.
    5. Once a valid base ID code has been entered, the
    display will blank for a second or two, and then
    show:
    6. If the base accepts the new handset, after several
    seconds the new handset will show:
    where X is the new handset number assigned,sequentially,
    by the base.
    NOTE: The 15-digit BASE ID Code may contain numbers and characters,
    including0 through 9 and *. Make sure you enter all 15 digits.
    De-register all system handsets by:
    1. Unplug the base power plug.
    2. Press and hold the PAGE key.
    3. Plug the base unit power plug back in and con
    tinue to hold down the PAGE key for 10 seconds.
    4. This will erase all handsets registered to the
    base. The handsets will now prompt you to:
    5. Enter the 15 digit base unit ID code, located on the
    6. Press SEL to complete the registration process.
    7. Once a valid base ID code has been entered, the
    show:
    8. If the base accepts the new handset, after several
    by the base.
    Follow this few steps, this was intend to register again your handset into your base.
  • micromaster
    follow up and update us again here..
    micro
  • micromaster
    micromaster Oct 14, 2008
    i have give instruction how to register the phone..
    did you follow the steps i given above..?
  • micromaster
    did you see my solution... ? i am waiting for you to respond on this..?
  • micromaster
    any expert can respond here, the user don't seem to see my solution..
  • micromaster
    micromaster Oct 16, 2008
    Hi Mktdds,
    My solutions was posted over here. i want to know if you have followed or checked my solutions.
    i can't provide another instructions while you don't give me further more idea and info on how you check and followed the steps provided here.
    let us know..
How to pick up a internal call from colleague extension?
Depending on the system the phone is connected to, you can dial 40 on the intercom or 4+1xx (the intercomed extension) to pick up the call.
40 will pick up anything ringing in your group, so if you want to be sure it's only going to answer your colleague's call, use the 41xx code.
If the code doesn't work, check out your user's guide for directed call pickup.
Carl
Dec 31, 2012 | Panasonic KX-T7730 Corded Phone
How do I change the number of rings before the answering machine picks up the call on my panasonic KX-T7633 phone
If this is forwarding to the answering machine on YOUR phone, from the intercom dial *713xx where xx is a number of seconds. I think by default it's using the system number of 40 or 45 seconds. Try 24 for 4 rings (or multiply the number of rings by 6 and you get seconds).
If you're talking about SYSTEM rings before the VM, it's a different story and it requires system programming.
Carl
Aug 24, 2011 | Panasonic KX-T7633 Corded Phone
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
How do I use the intercom function on a KX-T7731 phone??
Panasonic analog phones plug into analog KSU's and have extension numbers beginning with 101. In additon, you can dial 0 to reach the phone programmed as Operator, and it's usually extension 101.
With the intercom dial tone (press INTERCOM or pick up the handset or press SP PHONE) you can start dialing codes defined in your number plan. You can also program left side buttons to monitor are directly select other extensions or dial codes to page all idle speakers in a 77xx phone.
Note this is specific to TA series systems, but the operation is similar in all Panasonic models.
Carl
Apr 19, 2011 | Panasonic KX-T7731 Corded Phone
Panasonic KX-NT136 - how do you page directly to another extension and begin talking to the other person without them picking up?
It's not called page, it's INTERCOM. On the face of most Panasonic phones, there's a button labeled AUTO ANS. When you press it, it lights up. If the options are set properly, it becomes the Voice Announce/Auto Answer button. Every phone you want to have the VA feature on has to have that button lit. When you call them on the intercom, it will beep twice and your voice will be on the set and they may or may not be able to answer back handsfree.
It requires system programming and theere's a code you can dial to block it.
Carl
Mar 23, 2011 | Panasonic KX-NT136-B Hybrid IP Telephone -...
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
    There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
    The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
    Ringing is set in system programming.
    Carl
    Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
    ANSWERING INTERCOM
    I'm out in the field and not at my Partner system, but I think you can either program a button or dial 626 on the intercom.
    To program a button, press FEAT 00, the button, Intercom 626 and when that phone rings, pick up your handset and press the button.
    Carl
    Apr 24, 2009 | Avaya Corded Phone avaparp18d
    How do I retrieve messages on the Panasonic KX-T7030 phone?
    • Call into your mailbox (usually by dialing intercom 165)
    • Press 4, and 4 again (for "Incomplete call handling")
      By default, three options are enabled:
      option #1: leave a message
      options #5: call the operator
      option #6: return to top menu
    • Follow the audible prompts to disable options 5 and 6
    Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Receiver dosen't pick up line that is ringing
    go to programming section 5
    You want Automatic Line Selection
    Press feature00
    left intercom button press twice (system program)
    press right intercom once (central tel program)
    enter # of extension to be programmed (intercom #)
    press **
    press line buttons in desired order line1 line 2 etc and
    end with left intercom then press**
    enter feature 00 to exit programming
    Dave
    Aug 26, 2008 | Avaya Corded Phone avaparp18d
    Lands Phones Logo
    66 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
