Question about LG enV VX9900 Cellular Phone
No sound, cannot hear ring or people who answer
I can dial a number and my ringtones are audible, but I cannot hear a the rings when calling someone and if they answer or if someone calls me and I answer, I cannot hear anything at all. What might be the problem and how can I fix it??
Try playing around with the battery or hav someone call u (or call ur cell from ur house) and while ur connected try to turn the speaker on and it should work. after this u can turn it off. my enVs a pain too!
Posted on Oct 16, 2008
Why can;t I hear anything on outgoing calls
Cordless/Corded Phones, Digital Photo Frames 1-888-331-3383 Mon-Fri 7:00AM-7:00PM CST
Contact our team for assistance.
Mark
Motorola Support
Sep 14, 2014 | Motorola IT6-2 DECT 6.0 2-Handset Digital...
My phone has lost its sound and when someone rings it will only vibrate then when i answer, i can hear them but they cant hear me, I have checked and it is not on silent.
First make sure the phone is not on silent,
Try changing the ringtone, go into phone->options->sounds, make sure type is set to ring, if so select a different ring tone.
May 31, 2011 | HTC Touch P3450 Smartphone
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
My Nokia 2600 rings for about 10 seconds and I miss calls because I cannot hear the ringtone, even though I have turned it up to the max. I am not deaf.
Hi, some ringtones are quieter than others so try another ringtone, and if you want it to ring longer go into the settings then call settings then choose call diverts and then turn them all off, then turn the one on that says when out of reach and not available this will then keep the phone ringing when its on but when its off it will go to answer phone.
if you dont need to use or never use the answer phone just turn all the diverts off then the phone will keep ringing for ages when someone calls you
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 30, 2010 | Cell Phones
No sounds at all no ringtones, dialling tones, music etc. when i dial out i cant hear recipient of call but they can hear me, likewise when someone rings me help !!!!!!!
My boyfriend had the same thing wrong with his phone i told him to put it in a bag of rice and it might fix it and luckily it fixed it so try that i hope this helps
Nov 11, 2009 | Samsung U900 Soul Cellular Phone
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
My phone rings but i can't hear anything on the end
i have a GE 6.0 cordless telephone, i know tha it's ringing the number comes up on my television but I can't hear it ring?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
Kyocera candid ii will not send/receive calls.
you have to deactivate your call divert service for all
May 19, 2009 | Kyocera Candid KX16 Cellular Phone
My house phone rings when someone calls but we can't hear it ring nor can we get a dial tone to call out
The ringing you hear when you dial your phone number is not actually your phone ringing but a machine at the phone company designed to give you something to listen to while they connect your call. I would say that your phone number is working, just not at your house. You need to call repair to trace your phone line and get it connected properly. Good luck
Jul 17, 2008 | Lands Phones
LG enV VX9900 Cellular Phone Logo
270 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
