Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Carrage will not return to center
Stopped printing Tec could not solve problem. sent new print head. I installed new print head. Now print had stays to the right refuses to come to center.
    Problem Solver:
  • 19 Answers
Im sorry you are having that problem. you can try to download the latest firmware for your printer. this could correct the issue you are having but make sure that there is no attention lights or error messages on your printer before doing so and also make sure that the printer is connected to your computer. ive included the link for the website:
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
if this still fails, then you should consider calling the tech support back and ask them for the next recourse for that.
Posted on Oct 23, 2008
I installed a new print head. Now I think it needs aligning. How do I do that?
go to test print menu in diag mode
set the print conditions
set slant line 3 dots
align the head on the platen until the printing is clear.
Mar 13, 2015 | Toshiba TEC B-SX4 Thermal Label Printer
CANON PIXMA 500
Heads on inkjet printers block and sometimes even their electrics fail, most problems are previous use of inferior ink entering print head and ruining it, luckily canon print heads are easy replaced and just click out via the opening of the release handle on top of head, one does not clean print heads with much hope of success.
As a tec I'd advise you the fix for this is to replace the head with new, use only gen ink in new head
pic of a Canon pixma 500 print head
50a6e1f.jpg info on purchase($50) and part number
Feb 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
We have a TEC BSX4T laser printer that is not printing correctly. Once you type info in..press print..the printing becomes progressively off centered with each successive label. Someone suggested the...
Plce the media guide correctly and check that the roll is centered correctly. Else you may have a problem with the alignement of the head on the platen.
Aug 25, 2011 | Toshiba TEC B SX4T Printer
Epson BX300F Hello Had a paper jam and remove...
Have you tried aligning the print head? It should be an option on the Maintenance menu.
By the way, that carriage is called a print head. Try removing the print head (you have to remove the ink tanks first; be careful, they leak) and putting it back in. The instructions should be in your manual
Oct 22, 2017 | Computers & Internet
TEC B-572 printer, labels off center.
Check the alignement of the media guide. and the alignement of the print head. + X adjust parameter
May 15, 2010 | Toshiba TEC B-572 Printer
Epson c20ux -ink cartridges installation
Power on
Open door or front top of cover that covers cartridges.
Systen should move ink carrage to center so you can take out old and put in new.
Close door/cover and should get some data on Monitor to follow so system recognizes new cartridges.
If no work u have some type of a problem in printer.
I'm assuming you don't have a paper jam or anything. If you do must clear.
Luck
JC
Jan 18, 2009 | Epson Stylus C20UX InkJet Printer
Print head problems
take ink cart. out, there is a release button center top just below the hole in the middle of the print head. That releases the print head take out at an angle. Hope this helps!!!!!!!!!
Oct 23, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Carriage jammed
first open the door and ckeck out any optical in carrage moving area are not shigted if the carrage movoing area are free then ckeck in service station it is working properly or not if it is working properly then ckeck the endcoder strip and if it is also ok then reinstalled the mecanism your problem will be solved
Jul 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
CANNON MILTIPASS MP390
Hello Dear,
The Print Head in your printer is physically damaged and so even though it is present and installed it will not be detected by the Printer, you need to purchase and install a new print head for your printer and this will solve yore problem definitely, you can get this print head from any Authorized Canon Care Centers, if you do not get it there you can revert me back.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 17, 2008 | Canon SmartBase MP390 All-In-One InkJet...
TEC B431-GS10 problem- Print-out in labels are only half
Various possibilities:
- The data cable on the head is not correctly inserted.
- the head is out of order.
- You are printing with a driver with a lower graphic resolution than the head resolution
Mar 31, 2008 | Toshiba TEC B-SX4 Thermal Label Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
26 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
