Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Protron 4250 lcd 42"
TV started cycling from red to blue to green to white then melts to black.
Sound can be hear just no picture.
And think that just earlier today I was bosting about the great deal I got from Shop NBC.
Has anyone got the solution.
I am thinking repairman, trash it, count my loses................
The problem is the connetion between inmage source and motherbaord.
I can fix this kind of problem. I am in los Angeles
Where are you located?
Please email me : ednation@meidiusa.com
Posted on Oct 14, 2008
Why did it work before installation, now flashes numerous different colors?
Before installing replacement parts???
I can assume that the t-con board or the video board had terminal connectors or ribbon connectors. What is often overlooked is a misaligned connector or worse, a broken or bent pin. Try examining these connection points. You may have to use a magnifying glass. A defective screen usually goes black or produces broken images and/or color points.
I hope this helps.
May 30, 2015 | Protron PLTV-4250 42 in. LCD Television
Protron Pltv-4250 42 Widescreen HDTV LCD TV NO SOUND
Try disconnecting from power for 30 mins and connecting back
Apr 05, 2008 | Protron PLTV-4250 42 in. LCD Television
HDMI connection
A downloadable copy of the manual for a Protron PLTV-4250 is available here.
I went through it to check up on your concern. It was mention in page 34.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Protron > PLTV-4250
Feb 13, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron pltv 4250 keeps shuting off
Main digital board should be checked. In most case, might need replacement. Contact any service technician.
Jun 27, 2013 | Protron PLTV-4250 42 in. LCD Television
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
TV has video issues
that's bad dude. I think your'e picture tube of your television has a major problem.it's either damaged OR needs to be cleaned, you should fix to your liscensed/ qualified technician to fix that problem because the parts are very sensitive.
Jan 27, 2008 | Protron PLTV-4250 42 in. LCD Television
No picture/sound
power supply going bad. or went bad.
get one here. The have the best price.$60
and not $100-150.
http://www.power-on.com/lcd194-3f.html
Mar 17, 2009 | Protron PLTV-4250 42 in. LCD Television
Proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
Nov 22, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
101 people viewed this question
Top Protron Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
