Question about IBM NetVista PC Desktop
CMOS erroe 0193
Just recived IBM Netvista 2292-21u refubished mother board.
I keep getting "Error 0193 system security - IBM Embedded Security hardware has been removed". then "Error System Halted". Tried everything and still cannot enter bios using F1.
  • BurtK Oct 12, 2008
    Thanks, but I have tried this several times, still no joy. Tryied moving cmos clear jumper and flashing bios using floppy disk. This seemed successful but still ended up with the same error.
    Thanks for the additional help, Still no joy, Pressing F1 will not bring me to the normal BIOS menu.
    This is what I always get pressing F1 or F12 for start up devices.
    CPU = Intel Pentium 4 CPU 1,60GHz
    639K System RAM Passed
    254 Extended RAM Passed
    256K Cache SRAM Passed
    System BIOS shadowed
    Video BIOS shadowed Mouse initialized
    ERROR
    0193: System Security - IBM Embedded Security hardware has been removed
    ERROR
    System Halted
    ERROR
    0162: Configuration Error - Default configuration used
    After that the system hangs no reaction from keyboard.
    Genius:
  • 1,124 Answers
Remove the CMOS battery and also the jumper on the motherboard to reset the bios.
Posted on Oct 12, 2008
  • 2 more comments
  • Pablo Csaky
    Pablo Csaky Oct 12, 2008
    NetVista systems
    To run the System Configuration Utility, use the following procedure.
    1. Power off the computer and wait for a few seconds until all in-use lights go off. The option to run the System Configuration Utility does not appear if the computer is not cold booted.
    2. Power on the computer.
    3. When the System Configuration Utility prompt appears on the screen during startup, press F1. The System Configuration Utility menu will appear. If an administrator password has been set, a limited menu appears on the screen. In this case, to access the full System Configuration Utility menu, you must enter the administrator password.
    4. Follow the instructions on the screen.
    5. When finished, select System Summary to verify that any configuration changes have been accepted.
    The System Configuration Utility can also be accessed by holding down a key on the keyboard during boot-up. This will result in a "301 - Keyboard error".
    ThinkCentre systems
    Note: There are two different ways to access the setup utility on the ThinkCentre systems. One way is to use the F1 key and the other is to use the Protected Area Run Time Interface Extension Services (PARTIES) menu. The two ways to access the setup utility are listed below:
    Using the F1 Key
    1. Restart the computer or power off the computer and wait for a few seconds until all in-use lights go off then power on the computer. The ThinkCentre systems do not have to be powered off to access the System Configuration Utility, however it will not display the prompt to press F1 to access the System Configuration Utility unless the system is powered off and then back on..
    2. Press F1 when prompted from a cold boot or if the computer was restarted press F1 continuously until the System Configuration Utility menu appears on the screen. If an administrator password has been set, a limited menu appears on the screen. In this case, to access the full System Configuration Utility menu, you must enter the administrator password.
    3. Follow the instructions on the screen.
    4. When finished, select System Summary to verify that any configuration changes have been accepted.
    Using the PARTIES menu
    1. Restart the computer or power off the computer and wait for a few seconds until all in-use lights go off then power on the computer.The ThinkCentre systems do not have to be powered off to access the PARTIES menu, however it will not display the prompt to press enter unless the system is powered off and then back on.
    2. Press Enter continuously if the system was restarted or press Enter when prompted if the system was powered off and then back on, until the PARTIES menu appears on the screen.
    3. Double-click the "Start setup utility" icon to access the System Configuration Utility.
  • Pablo Csaky
    1. Turn off the computer and any attached devices, such as printers, monitors, and external drives.
    2. Unplug all power cords from electrical outlets, and remove the cover.
    3. Locate the Clear CMOS/Recovery jumper on the system board.
    4. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
    5. Move the jumper from the standard position (pins 1 and 2) to pins 2 and 3.
    6. Replace any adapters that were removed.
    7. Replace the cover.
    8. Reconnect the power cords for the computer and monitor to electrical outlets.
    9. Restart the computer, leave it on for approximately 10 seconds.
    10. Turn off the computer by holding the power switch for approximately 5 seconds.
    11. Unplug the power cords from electrical outlets.
    12. Remove the cover.
    13. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
    14. Return the Clear CMOS/Recovery jumper to its original position.
    15. Replace any adapters that were removed.
    16. Replace the cover and reconnect any cables that were disconnected.
    17. Turn on the computer. The computer should sound 2 beeps. The time and date should need to be set. If not, the procedure did not work.
    18. After resetting the date, time, and saving the settings, exit the System Configuration Utility.
  • Pablo Csaky
    That's sounds weird.
    But you can try again with a floppy updating the bios and see what happen
    If power to your computer is interrupted while BIOS is being updated, your computer might not restart correctly. The Clear CMOS/Recovery jumper enables you to restart the system and recover the BIOS. To perform a Flash/BIOS recovery using the Clear CMOS/Recovery jumper, use the following procedure:
    Before proceding, be sure to review the safety information.
    9. Insert the POST/BIOS update (flash) diskette into drive A, and turn on the computer and the monitor. The system will begin to beep.
    10. After the update session is completed, there will be no video and the series of beeps will end. Remove the diskette from the diskette drive, and turn off the computer and monitor.
    17. Turn on the computer to restart the operating system.
    18. You may now want to update the BIOS normally. Refer to the readme.txt file that came with your flash BIOS update.
    Additional information
    • If the power button is pressed and the power light does not come on, then boot block recovery will not work. Inspect power to the system board and replace power supply or system board based on normal problem determination.
    • If the power button is pressed, the power light comes on, but there is no video, try boot block recovery. There are several possible causes. The most common is a corrupt Extended System Configuration Data (ESCD) sector in BIOS. Boot block recovery will fix this problem.
      1. Sometimes the floppy diskette drive will not be read during boot block recovery. In this case, the fans are usually running loudly at full speed. If the floppy drive is not read, the system board must be replaced. This could happen when there are solder cracks on the North Bridge.
      2. If the floppy diskette drive is read, once boot-block finishes, and video does not return, replace the system board.
      3. If video returns, the system will have to be flashed again using the normal flash process to reset the serial number, machine type, and model number in BIOS. This could happen when there are corrupt BIOS sectors.
    • If the power button is pressed and video comes up normally, but a hang occurs in POST before the Windows splash screen, try boot block recovery. This could happen if power was interrupted during a normal flash procedure and BIOS is corrupted.
      1. If the problem remains after boot block recovery, use normal problem determination and replace the system board, if necessary.
      2. If the hang goes away, then the problem is solved.
    • If the power button is pressed and video comes up normally, but a hang occurs on or after the Windows splash screen, it is most likely a driver or operating system error and boot block recovery will not help. Run PC diagnostics. This should not be a planar problem.
  • Pablo Csaky
    You will find the drivers and bios for your netvista here:
    http://www-307.ibm.com/pc/support/site.w...
0912:system security ibm embedded security hardware tamper detected.error system halted
There is a switch in the machine that gtracks if the case has been opened. Alkl you have to do it to run the setup, by entering the BIOS setup routine.
Feb 09, 2015 | IBM Computers & Internet
IBM embedded security sub system
is this a laptop?
if so tape down the cover switch (this is a mini switch on the mainboard)
Feb 25, 2012 | IBM ThinkCentre M50 PC Desktop
I am not sure
Code 5962: An IDE device (other than hard drive) configuration error.
Things to check:
  1. Run configuration
  2. CD-ROM drive
  3. CD-ROM adapter
  4. Zip or other ATAPI device
  5. System board
  6. Riser card
Regards
Jun 23, 2009 | IBM NetVista PC Desktop
CMOS Error 0193
The security device plugs into the left front of the MB as viewed from the front. It is approximately 1.5" x 2 inches in size. they sometimes come loose form the socket when a system is moved. Open the case and see if it is there and loose. If completely gone, then you need to contact your MB supplier for either the device, a new board or a factory reprogram of the board to disable the missing device.
Oct 12, 2008 | IBM NetVista PC Desktop
IBM NetVista8305-MU3
Thanks for the note back. It has one vga port on the back and it's on the main(mother)board.
Sep 05, 2008 | IBM NetVista PC Desktop
Need i driver
your solutioni s here
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42808
Jul 31, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
Re:Bios jumper
Your computer is an IBM Netvista 8311.
This link shows ibm netvista 8311 motherboard diagram
www-307.ibm.com/pc/support/site.wss/document....
The cmos reset jumper it is indicated on nr.10, alternatevely when you cannot find reset jumper on a motherboard you can pull out and put back motherboard battery
Best regards
Mar 17, 2008 | IBM NetVista PC Desktop
Monitor screen shows all sorts of colors in line patterns.
with the information I gathered IBM netvista does not features a video card, it is inbuilt. So it shares your system memory. just open the sysyetm chassis and take out the RAM module and clean the contact edge with a rubber eraser (pencil eraser). Re insert the RAM module and try again.
If the problem persists. try changing your memeory module(s).
Oct 28, 2007 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
1,584 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
