Question about LG Televison & Video
I have an LG 389H VCR / DVD recorder and when I start dubbing a tape onto a DVD, it always stops half way through the tape even if the DVD is not full. Even if I put another DVD it does not continue.
SOURCE: Problem dubbing VCR - DVD
I have 3 of these machines. I do not think it likes theRW disc's. Two of my machines are 4X & one is 8X. I have very great success with 4X DVD-R & 8X DVD-R disc's. I hear they have a fix for upgrading to 8X speed. Here is the link with the information:
You can still buy the 8X speed disc's on the internet. Hope you can get the machine to work, because I love the ones I have.
Posted on Apr 22, 2008
  • 476 Answers
SOURCE: PHILIPS DVD/VCR Player Direct Dubbing
No. This unit is a video recorder & DVD player only.
Posted on Jun 10, 2008
SOURCE: unable to "dub" my 8mm tapes onto DVD-R using my Sylvania DV90VE
From comments posted on the Internet by other Sylvania users with a similar problem, I  learned that I had to use a 4X DVD-R (the ones I had been trying to record on were 16X). And I found that Office Depot sells the sometimes hard-to-find 4X format, so that's where I'm headed right after lunch.  Thanks.
Posted on Dec 15, 2008
SOURCE: VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Posted on Jun 05, 2009
SOURCE: dubbing vhs to dvd
Please thank Stu for scanning this. I have uploaded the manual to my personal web page. Just click the link and the word document will download. (why is it so hard to record with this thing? Shouldn't there just be one button? Broksonic has taken years off my life, but not anymore)
your welcome,
Posted on Jun 27, 2009
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
Apr 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Open Questions:
I have a LG 50 LCD TV Model: 50LN5700-UH that has a black screen. There are a couple of things I have tested and replaced. First off there is audio but just a black screen. I turned off the lights and looked for signs of back lights. When I did this there were no visible signs of lights. In addition, I did the flashlight test. Which showed visible signs of lettering on the screen with the flashlight. Which if I understand correctly it may determine that the T-Con board is functional. I ordered additional LCD's from Shop Jimmy and replaced the bad sticks. About half were replaced. I reassembled the TV and I am still getting no video, but I still have audio. However, this time all the LCD's are functioning so now the screen is still more grey than black because of the working LCD's I replaced. What voltages and at what points should I be testing to narrow down the problem, or what other problem-solving technique should I be testing? One other thing I should mention is there no visible signs of swollen capacitors or any signs of burn marks. I am 99% sure I connected all of the cabling up correctly, not 100% since this was my first attempt but I am a little less confident I put the filters in the correct way. I had the TV disassembled while I was waiting on the LCD's to ship and when I re-assembled I was less confident if I picked up all 3 or 4 filters and set them down, or if I make have flipped the filters to keep the circuit board on the front cover from being damaged. Hope that make since.
Mar 16, 2018 | LG Televison & Video
Televison & Video Logo
163 people viewed this question
Computer Repairing
Computer Repairing
