Question about Toshiba 42HL67 42 in. LCD Television
No responding to remote
TV is stuck on Channel 73, wanted to change channel but no response. I did the troubleshooting according to manual but no change. Also TV will not shut off
Thanks Ed
  • Anonymous Jan 06, 2009
    remote sensor on magnavox tv broke,so remote won't work.not digital and was trying to connect to digital box. stuck on ch.73 and can't change channels with front panel buttons either.
  • matrixmaw Jan 11, 2009
    magnavox remote sensor broke so remote does not work. tv stuck on ch.73. tried unplugging, didn't work. need to set on ch.3 for digital box....
    President:
  • 2,712 Answers
Unplug the TV from the AC Power source (wall socket) for about 10-15mins and then replug and see if it works.
Posted on Oct 12, 2008
  • Swilin Sampson
    Swilin Sampson Oct 13, 2008
    If your issue is not resolved, please do not assign
    a rating just yet. Please post back as to what steps you took, results, etc,
    and I will try to assist you further as best I can.
    P.S. - You can rate a
    solution with one of four ratings as explained under (remember that at times a
    bit of to and fro dialogue may be necessary to resolve an issue).
    • "FixYa!"
      - The solution provides great advice that helped solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
I need to get my TV on channel 73 and i can't figure out how to do that
To get the tv on channel 73 you will need to use your remote that came with the tv. Type in channel 73 then hit ok or select. Or you can change the chanel buy using the channel button on the Tv.
Dec 26, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
TV stopped responding to remote control
Unplug Tv from power source, wait 10 minutes and replug
Oct 12, 2008 | Toshiba 42HL67 42 in. LCD Television
Hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
We would be happy to help with that. Some TV's are not ableto go as high as channel 73. This sounds like you're having an issue with yourTV2, this would be the TV located in a different room than your DISH Networkreceiver. Go to the main TV by the receiver, press the menu button located onthe top left of your DISH remote. Once in the main menu, press the numbers6-1-5, this will take you to the "Modulator Setup" screen. Once there we want to highlight the "Air"option located below "TV2 Out" then press the select button. TheChannel should change from 73 to 60. Change the channel of the TV you arehaving an issue with to channel 60; you should get the DISH Network programmingat that point. We hope these steps help you get that fixed. Thank you for beinga valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 16, 2010 | Haier HTF20 20" TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
I can't put my tv on channel 73 it will only go to 69. toshiba cf32c50
You may want to go in the menu and look for add/erase channel or just do the autoprogram, it should add any channels that have a proper signal
Nov 01, 2009 | Tvone TV-207 Television
I can't change the channels on the tv with remote or on tv controls. The channel up button on the tv only goes to channel 1 or aux. I need channel 73 to use satellite service. We have changed batteries in...
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
Jul 03, 2009 | Emerson EWF2704 TV
Tv does not respond to channel changes
The simpliest solution is always the best - I called the cable service provider; they reported an outage and quickly remedied the situation - but also tried to sell me their digital TV package. Thanks for your response.
Feb 16, 2008 | iLO 3200 32 in. LCD Television
Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Feb 05, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Remote control no longer works
an original remotes available for ya at http://www.remotes.com for 30 bucks + shipping
Apr 23, 2006 | Sylvania 6319CC 19 in. TV/VCR Combo
Toshiba 42HL67 42 in. LCD Television Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
