Question about Akai Televison & Video
Pictue on my 55" projection tv
The picture is pulled down from the top and up from the bottom at the center of the screen. The picture and color is distorted. What could be wrong with it?
    Sergeant:
    Champion:
  • 227 Answers
Hey my friend replace the convergence ic's (stk.....) that is your problem
caypianan@yahoo.com
Posted on Oct 12, 2008
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | RCA HD52W59 HDTV Projection Television
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Warpped TV picture
There are two problems here but may be caused by one component
The flyback transformer or transistor equivalent is faulty The colors are warped convergence controls which may be due to a faulty sustain board or part of the first problem. DIY is not an option and repair estimate is about $3-400.00
Please rate my help++++Thanks for uyisng FIXYA
May 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
We have Phillips 55 in rear projection TV and just set our color convergence back to factory settings but we still have an awful picture. Any suggestions? All objects have multiple halo bars on them....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips 55PW9363 55" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
SAME TV(mitsubishi HD1080 series)-- corners of screen are bent
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 21, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Phillips 55PW9363
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | Philips 55PW9363 55" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
