Question about Toshiba 42HL67 42 in. LCD Television
TV stopped responding to remote control
The TV is on Channel 73, I wanted to change the channel but there was no response and also will not turn off. I followed instructions in the troubleshooting manual by holding the POWER button on the TV control panel(is this the same as the remote control) but TV did not reset itself.
Need help.
Thanks ED
  • ur1poppop Oct 12, 2008
    TV not responding to remote. can not shut off or tune in another channel. Unplugged for 10 to 15 minutes and still did not work. I did what the manual told me about pressing the power button for 5 seconds to rest..Did not help
    I solved the problem. The mode select switch was on the wrong setting. Thank you for your time
    Genius:
  • 1,124 Answers
Replace the batteries of your remote control first.
Then be sure to hit the right button in your remote control, Usually the remotes control no respond because when you hit the channel key the key top button are indicating a different function like (tv, video, cable, aux) In that case you have to hit first tv or cable and then hit the key of the channel desired
Posted on Oct 12, 2008
    Sergeant:
  • 352 Answers
Is the remote a universal remote or the remote that came with the tv. If its a universal re-enter the code for your set. If it is the remote that came with the tv, your user manual will explain how to reset the remote. At least it does with my tv, hopefully yours too. Also check your manufacturers website for troubleshooting help
anaanymous
  • anaanymous Oct 12, 2008
    sorry, forgot one thing. You can find the reset code for the universal remote in the pamphlet that came with the remote.
    anaanymous
    Brigadier General:
  • 3,614 Answers
What is your TV model, and are you using a Universal remote for that.. kindly input here what the specific name of the device..
if you were using a universal remote, this will need to be reprogrammed again into your tv and able to use it again..
  • micromaster
    micromaster Oct 13, 2008
    kindly rate this solution.
    thanks
    Sergeant:
  • 399 Answers
Shut off the tv directly from the main power outlet.remove the plug from the outlet.also change the remote batteries.and reinsert the wire after 10 minutes.and check it will work as normal.
thanks.
    President:
  • 2,712 Answers
Unplug Tv from power source, wait 10 minutes and replug
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Is a Insigna TV, it turns on by it self and starts changeing channels and I can't stop it I have to unplug it.
the problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Televison & Video
I need to get my TV on channel 73 and i can't figure out how to do that
To get the tv on channel 73 you will need to use your remote that came with the tv. Type in channel 73 then hit ok or select. Or you can change the chanel buy using the channel button on the Tv.
Dec 26, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
I cant convert my 24" ViewSonic remote to my Comcast remote
Try and re-do your codes for your remote. If you don't have the codes try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | ViewSonic NextVision N3260W 32 in....
The TV does not respond to the channel changer. changed to a new changer and batteries but did not correct.
Do you mean changer is a remote control? Try to use manual buttons to see whether the TV work. If it does not response either the problem comes from the input/output controler or main board.
Aug 11, 2009 | LG 42LC2D 42 in. LCD HDTV
No responding to remote
Unplug the TV from the AC Power source (wall socket) for about 10-15mins and then replug and see if it works.
Oct 12, 2008 | Toshiba 42HL67 42 in. LCD Television
Toshiba 42HL67 42 in. LCD Television Logo
557 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
