Question about SanDisk Sansa e250 MP3 Player
Sansa e250r Media Player
Is there any way to make it like the normal e250, not with the rhapsody thing?
So did you get your answer, or do you still need a solution. Stop confusing me =P
If you still need an answer, and I think I know what your saying, then without using rhapsody you can connect to your Sansa e250 VIA "My Computer" in the "Start Menu" and click and drag music onto your Sansa e250.
Hope that helps
Posted on Oct 29, 2008
Sansa e250R firmware
hey yeah i had the same problem with my sansa e250r. when mine does that i
1. turn it off
2. put the hold button on
3. hold down the rec. button
4. turn it back on
that will get you into recovery mode connect your data cable once you have hooked it up to your computer open my computer and you should see a 16mb drive there instead of your normal mp3.
once you see that open it up.
now go to scroll down and click on download firmware link
once you have downloaded that file unzip it and copy the file that is inside to the 16mb drive that you opened up in my computer.
once you have done all the above,,
1. take the hold button off
2. disconnect the data cable
3. wait for it to reboot.
if the above dosent work you might wanna take it to the dealer.
hopefully this works for you as well as it did me. good luck
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250
hey smart ones(sarcasm) why dont u just buy the Sansa e250v2
its pretty much the same thing, just without rhapsody, thats how me and my friends are, i bought the one with rhapsody features(Sansa e250R) so i can play the songs that i bought and get free music channels for it, where my friend on the other hand has the Sansa e250v2 without rhapsody, u can still use rhapsody but u cant get free music channels for it, or u could also download best buy music manager or rhapsody and set up a free 31-day account for it to stop saying that for a while, plus if u got ur Sansa e250R from Best Buy, they can replace it, or trade u the sansa that u have with the rhapsody-free one(without rhapsody)
Feb 01, 2008 | SanDisk Sansa e250 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
Just view the folders with explorer and delete them, i've never had this problem, but im sure this will work
good luck
Dec 20, 2007 | SanDisk Sansa e250 MP3 Player
Restoring factory Sandisk Sansa e250R settings...
you might want to try right clicking on your mp3 icon while in rhapsody and clicking format device...
Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
Can't download to mp3
Make sure the device is in Rhapsody or MTP mode. Otherwise, the licenses will not transfer. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
New player, says I ran out of space
If you formatted it thru Windows Media Player, or Rhapsody, it didnt really format properly. Make sure the device is in Rhapsody Mode. Settings>Mode or USB Mode>Rhapsody. On your computer go to Disk Management. Right Click on My Computer and select Manage. On the next window select Disk Management, under Storage. On the right side at the top of the window you will see the device listed (i.e. Sansa e250r). Right click on the device and select format. Dont select any other options, just hit Start. Your device is now formatted properly. Best of Luck.
Sep 13, 2007 | SanDisk Sansa e250 MP3 Player
Hi tooky. Getting a "Bad Track" message on the E250 may be an indication of memory corruption, music file corruption, or outdated subscription/license info. One solution would be to format your player in Windows Media Player (version 10 or 11): 1. Make sure your player is in MTP mode by navigating the menu as follows: Menu > Settings > USB Mode You would get a choice of "MTP" or "MSC". Please select "MTP". If your player is an "E250 Rhapsody series" player, select "Plays for Sure". 2. Plug your player to your PC and run Windows Media Player. Click on the "Sync" tab and make sure the E250 is listed. Look for the "Format" button (it would look like a "pencil" on Windows Media Player 10) and click on it. Follow the on-screen prompt. 3. Re-load your songs by either copying/pasting your songs to the player or by using Windows Media Player's "Synchronization" feature. You could also format the player while in "MSC" or "Rhapsody" mode by browsing the player in Explorer, right-clicking the drive letter corresponding to the player, then select "Format". Follow the on-screen prompts Another solution would be to update the firmware of your player by downloading the Sansa Firmware Updater using this link from the SanDisk website (instructions are found on this site as well): For standard E250 or E250R "Rhapsody Series": Make sure your player is set to MSC mode, or "Rhapsody" Mode The type of music file might also be the cause. If your music files are licensed, purchased or acquired via subscription, you may want to contact the provider for more info on how to re-download the music files. I hope this helps. There are other procedures available but these might actually make your player work normally again. Hoping for the best :)
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
