Home | Samsung | SyncMaster 970P (Silver) (Black, Blue, Red... | Problem with crosshairs
Samsung SyncMaster 970P   19" LCD Monitor
Problem for Samsung SyncMaster 970P (Silver) (Black, Blue, Red, White)...
By lawyer - usenet poster
Hi all,
I've changed my resolution in UT99 from 800??600 to 1284??1024 and now all
crosshairs look too big and blurry, making it rather hard to aim with.
I'll need to use this resolution once my new 19" LCD arrives since it is its
native resolution, so I'm wondering is there a way to make crosshairs look
normal again?
Thanks.
Solution #1
posted on May 27, 2006
Not Rated)
Ross
Rank: Apprentice
Rating: 0%, 0 votes
I did but no luck. My new LCD arrived today and I found out that using lower
interpolated resolution in UT doesn't look all that bad.
Guess I'll play like that, bah.
Nice model, I was considering it for a while. Mine is advertised as 6ms gray
to gray and I can pretty much say it is as responsive in games as my old
CRT, 997NF.
Cheers and happy fragging!
Was this helpful?
Yes
No
Solution #2
Not Rated)
herself
Rank: Apprentice
Rating: 0%, 0 votes
Have you tried messing with the crosshair style in the options? I think
you can in this game (like most deathmatch games), and perhaps just
inkering with it will send it back to normal.
I have an AG Neovo 19" LCD @ 12ms and it runs awesome for games. Cheers!
Shinnokxz - #
Was this helpful?
Yes
No
Solution #3
Not Rated)
Peter1
Rank: Apprentice
Rating: 0%, 0 votes
This is from Samsung's site -
6 ms (g to g) response and pva panel does sound good, some nice viewing
angles too.
E4.htm
Afaik, Dell 1905FP comes in two versions, one with 20ms and other with 8ms
response time panel. You most likely have 8ms version (or eyes with an
interesting anti-ghosting feature :)
Luckily my crappy V9570 has one, so I'm sticking with it for now.
Cheers.
Was this helpful?
Yes
No
Solution #4
Not Rated)
M0nica L
Rank: Apprentice
Rating: 0%, 0 votes
angles too.
E4.htm
Cheers.
Was this helpful?
Yes
No
Solution #5
Not Rated)
Jimmy NY
Rank: Apprentice
Rating: 0%, 0 votes
I took a peek at the 970p and the specs don't really look all that
great. Response time is 20 ms which is a bit high for a TFT panel.
Some mfgs. today are offering as low as 8 ms response time.
But I can't really talk, since mine (Dell 1905FP) is also advertised
at about 20 ms
but seems to do fine. I read dozens of reviews of my monitor before I
bought it, and while some people loved it others complained about
severe ghosting. Personally, I never see any ghosting but then I'm
looking at it through 52 year old eyes. ;-)
My only recommendation is to use a DVI connector. If your vid card
doesn't have one then maybe it's time to switch to one that does. An
analog connection simply won't do any LCD monitor justice.
Was this helpful?
Yes
No
Solution #6
Not Rated)
Horner
Rank: Apprentice
Rating: 0%, 0 votes
I already made a bunch of my own (a bit of a crosshair freek here, he he).
The only one that I find usable now is a single pixel dot which looks almost
as a normal dot, minus some clarity though. Anyhow if I find some other
solution I'll post it back here.
Was this helpful?
Yes
No
Solution #7
Not Rated)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Yes, I wanted to see if UT99 would even run at that resolution since it's
not selectable from menu and I had to manually put it in
unrealtournament.ini.
This is how default crosshair looks like on 1280x1024:
Not pretty :/
I guess it's an UT99 specific thingie then. I can only hope then to get a
bright dot pixel at the exact center of my new screen.
On a side note - are you satisfied with how your LCD performs in games?
I decided to go for Samsung 19" 970p. Its specs look great but I'm a bit
anxious about how it will turn out in practice.
Was this helpful?
Yes
No
Solution #8
Not Rated)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
Yes, UT scales them rather poorly at the larger resolutions.
I don't know a fix, however there are user-made crosshairs around that
might be an improvement - google for "ut crosshair" to find a bunch of
sites and instructions.
Flash
Was this helpful?
Yes
No
Solution #9
Not Rated)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
I'm assuming that you're changing your existing CRT to that resolution
to test? All things being equal, your crosshairs (and everything
else) should have gotten smaller and sharper, since that's the normal
outcome from going to a higher screen resolution.
Maybe you should wait to see what they're actually going to look like
on the new monitor. FWIW, I went from a 1024 x 768 CRT to a 1280 x
1024 19" LCD and didn't have any problems with crosshairs, although
I'm playing UT2004 and not UT99.
Was this helpful?
Yes
No
Popular Solutions for Samsung SyncMaster 970P 19"
Questions and Unsolved Problems for Samsung SyncMaster 970P 19"
Do you recommend Samsung SyncMaster 970P (Silver) (Black, Blue, Red, White) 19" LCD Monitor?
Answer
Answer
our wd57381 hdtv is not working well, the color is red and suddenly turns out green. how to fix... (More)
Answer
Hi have the same problem - started about a year after I got it. I took the covers off to look at it... (More)
Answer
No there was nothing unusual. I had been in the habit of raising and lowering the screen. The hinges... (More)
Answer
The monitor is no longer supported by the flexible hinge. Is there any way I can tighten it? I have... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung SyncMaster 970P 19"...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 482
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
