Question about Kenmore Elite 45986 Front Load Washer
Door will not unlock need to get clothes out
Machine will not unlock need to get clothes out. How do I unlock? I'm five minutes from getting a hammer and breaking the sight glass.
  • Kenmore Master
  • 2,651 Answers
Whooaaa put down the ha\mmer, it wont open if theres too much water in unit. there is a manual release, but you have to remove the lower service panel to reach it.after removing the panel youll need to stick your hand up along side the front panel right hand side. the lowest ponit of the door latch/lock assy has a quarter sized handle that youll need to pull to relesae the door mechinism., WARNING if there is water visble through the door and you open it you will get wet...before trying the manual release option turn off the water supply and set the machine for drain/spin cycle and see if the drain pump turns on to release enough water to opne the door on its own,if the drain pumps only humms and doenst drain, then theres the issue you have something stuck in the drain pump. in which casse youll need to remove the lower panel and free the clog anyway.
Posted on Oct 12, 2008
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet sport front load washing machine
F-01 is a communications error between the CCU and EEPROM. The first thing to try is unplugging the machine for 5 or 10 minutes. If that doesn't fix it, you'll need a new CCU (probably need to replace that anyway). Though if you just got it 2 days ago, call the store you bought it from - they should replace it (and help you get it open to get your clothes out).
Sep 07, 2007 | Washing Machines
LG Washing Machine has DE Error code
<span><b>A DE Error Code is indicative of a "Door Error". This indicates that the washing machine </b></span><span><b>door is not shutting, locking or opening</b></span><br /><br /><span style="font-weight: bold;">Is this happening mid-cycle or at the end of the cycle?</span><br /><br />If this is happening mid-cycle or at the end of the cycle, try powering off the unit and unplugging it. Leave it unplugged for about five (5) minutes. Plug the machine back in, power it on and see if the door latch releases. If it does not, service will be required.<br /><br /><span style="font-weight: bold;">Is any item caught in the door?</span><br /><br />If an item is caught in the door, this could cause e DE error code to appear. Unplug for about five (5) minutes. Plug the machine back in, power it on. If the door will not unlock still, it could be that the item caught in the door could be pushing up or down on the door, preventing the latch from unlocking. May need service. <br /><br /><span style="font-weight: bold;">Has unit been paused in cycle to allow item to be added?</span><br /><br />During the Cycle, the unit will draw in hot water to help activate detergent, even on a cold cycle (no damage to clothing will result, as it is a small amount). When the unit is paused, if it detects that the water in the unit is to warm, it will not unlock the door immediately (takes a minutes) This is a safety feature.<br /><br /><span style="font-weight: bold;">Is the door or gasket warped or damaged?</span><br /><br />If the door is warped, it will prevent the unit form latching or locking properly. This can result in DE error code. Also, if the gasket is damaged it could cause this problem as well. Make certain the latch on the door is not broken. Refer to warranty policy to determine coverage under the LG warranty.<br />
on Jun 02, 2011 | Washing Machines
Door won't open
If you're going to trash the machine, then you could use a large pry bar to force the door open from the hinge side - or a Framing hammer, with splayed flat forks. drive the prying instrument into the hinge side of the door with a hammer and pry away!
Hope this helps!
Dec 17, 2013 | Maytag MAH8700A Front Load Washer
Sampsung wf7708n6w1 door won't open!
Your door switch/lock is broken, you need to unplug the machine and remove the top, you can then reach down (tight space) and using a small screwdriver you can pry around the switch and get the door to open, you need to get a replacement door switch for the machine.
Leaning the machine back can make it easier to access the switch.
Mar 06, 2012 | Samsung Washing Machines
Door is closed and the light stays on. after a while non of the buttons will work any suggestions.
I have the same problem but my interior drum light stays on whether door is open or closed; in either case the control panel becomes in-operable after about five minutes. I unplug the machine for 5 to 20 minutes then plug it back in and it is powered "on" the moment I plug it in (i don't even have to push the power button). Then the light remains on but i am able to operate the control panel so i can do a load of clothes. Then if the machine sits idle for no more than five minutes, the control panel becomes in-operable again and the interior drum light stays on.
Any one have a clue???
Nov 09, 2010 | LG WM2501H Front Load Stacked Washer/...
Door won't open after wash code or error..
lg huh... go get a hammer or something heavy and break the door glass to get clothes out.... lol ?LG this is whut u get when u buy that shizzzit lol sooorrry but it seems like noone can get parts or service on this brand is what my joke is about., soooorry at ur expense though i jusst had to say that ......well try unpluggin or killin breaker power to unit for five minutes, also make sure no control lock buttton is activated, some machines have a latch up underneath might need to remove bottom panel is acccesible thats bout it hope this helps once again soory for the foul weatherd joke...gooday mate
May 21, 2010 | LG WD-1280FHD Front Load Washer
Maytag MAH8700 - NP error code - Door locked and won't open
I don't know if you are aware of this, but Maytag did a recall on this washer in March 2007 where there was a risk of water leaking into the control panel and shorting out the board. You can follow this link to see if your washer was affected based on the serial number:
Here is a link to your user manual to see if it offers any help. The only thing I saw was to use the Cycle Selector button to unlock the door.
I found this on the Maytag site:
Is the door locked and the Add A Garment or Add Clothes light off?
If the Add A Garment or Add Clothes light is off, then the washer door will unlock after the Pause/Off or Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
You could also try their customer service number to see if they have a script for this problem: 1-800-688-9900
The only other solution I can offer is to disassemble your washer if its that urgent and you can't get a repairman out there.
Jan 10, 2009 | Maytag MAH8700AWM Neptune Front Load...
Door Locked
Did you try to unplug the unit for five minutes to see if the system resets and the door opens?
Please leave a rating
Dec 08, 2008 | Kenmore Washing Machines
Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Nov 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
196 people viewed this question
Sal De
 Brian Main
Brian Main
