Question about HP Office Equipment & Supplies
HP Photosmart C6100 All-in-One series. Ink system has failed. Error 0xc19ac3ff.
  • 2 more comments
  • hadmed Oct 12, 2008
    Preseed on/off button - panel showed "shutting down" and button light flashing, but has not shut down yet after more than 10 minutes.
    Pressing all the buttons for a long time and then the off/on button did not make any diffrence. Still 'shutting down'. Should I just disconnect it at the power point.
    When switched on again, came up 'ink cartridges missing ... Refer to printer documentation'. I reloaded the cartridges but the panel message has not changed. I then pressed 'ok' and when that didn't work, I pressed 'cancel'. No change.
    The 5 minute wait before re-connecting power and switching on again appears to have worked. I will accept this one. There was another 'solution' came in after this one but I did not need to try it.
    Kind regards
    hadmed
    Sergeant:
    Champion:
  • 435 Answers
Hi, I read through all the solutions and your updates.
It seems that you need to service it by HP.
Posted on Oct 13, 2008
    Sergeant:
  • 352 Answers
Uninstall printer and printer software completely. Create a new folder on your desktop and name it c6100drivers. Go here: http://h10010.www1.hp.com/wwpc/us/en/sm/WF10a/18972-18972-238444-421635-410635-1153695.html Navigate to support/drivers>your model>look for available downloads> download your models latest software update to the new folder you created on your desktop. Power down your computer>reconnect the printer to the computer and turn the printer on>Power on your computer. Windows will detect new hardware and ask you if you have the manufacturers intsall cd or a location where the install files can be found. Direct the wizard to your new c6100drivers folder. Follow the rest of the setup and your done.
anaanymous
Posted on Oct 12, 2008
    Brigadier General:
  • HP Master
  • 3,614 Answers
This can be a possible problem, check on this and try to correct this error ;
1. The printhead is overheated. Wait a few minutes; the printer resumes printing automatically once the printhead cools.
2. The printer may not fully ejected your paper. Remove the paper by hand ; the Paper Out light goes out. If you are printing a multiple-page document, insert a new sheet of paper into the paper guide. The Pause light goes out and the printer automatically loads the paper and resumes printing.
3. Move the paper a little to the left or right. Reinsert the paper all the way into the printer. Make sure that the edge guides are not too tight and abstructing the paper. Set the paper release lever to the single-sheet position if you are using single sheet.
-or-
Reset the Printer; Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If you have completed all the steps listed above and are still experiencing a problem, service the product.
  • micromaster
    micromaster Oct 12, 2008
    try to replace or another ink cartridge, so we can look out if it is the cartridge is defective.
    let us know again here.
    President:
  • 2,712 Answers
Try a hard reset:
Unplug the printer from the AC power source (wall socket) and PC, wait about a minute and reconnect to PC and plug into wall socket. (You do not have to press the ON/OFF button to switch off the printer in this method).
This should reset the printer.
If even this does not work, it could indicate a circuit problem or a problem with the logic card (controller chip). Best call it in for service or purchase a new printer (whichever works out cheaper).
Cheers!
IrishDruid
    Genius:
  • 1,124 Answers
Remove the printer cartridges
Turn the printer off.
Unplug your printer from electricity
Wait 5 minutes
Connect all again
Start up your printer
Insert the cartridges
This will fix yor problem
  • Pablo Csaky
    Pablo Csaky Oct 12, 2008
    Your printer if not respond or still continues sending error messages need to be serviced or replaced. Like last option you can try replacing the cartridges for new ones and see what happen.
    Genius:
  • 3,422 Answers
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
http://h10025.www1.hp.com
NOTE: Clicking the links may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
Now, check the functionality, if the issue persists, please perform the below steps.
  • HP Master
  • 6,487 Answers
Try this one for this problem:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the C6100 OFF. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
Hope that helps.............
    Sergeant:
  • 399 Answers
Please remove the inksystem and also remove the cartridges from the printer and clean the circuit of both cartidges and the printer.the circuit is brown in colour and dotted you can easily see it on the cartridges and printer.clean it with tissue then install every thing again as normal and check it .
    Genius:
  • 1,550 Answers
Restart your printer atleast for the moment the error can be removed and it will work properly .
ERROR OXC18A0301 HOE DO YOU FIX IT?
look solutions on
http://h30434.www3.hp.com/t5/Other-printing-questions/C6100-All-in-One-message-Ink-System-has-failed-Error-Oxc18a0301/td-p/25751
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | HP Photosmart 3210 Printer
What is printhead failure on my HP Photosmart C6100 series printer? and how can I fix it permanently?
The print-head is the "heart" of an ink-jet printer -- it pulls the ink from the ink-cartridges, and sprays the ink onto the paper.
If the "manufacturer-warranty" has expired, it is time to buy a new unit, and to responsibly recycle the old unit.
Jul 30, 2010 | HP Photosmart C6100 All-In-One Printer
I have a HP Photosmart C7280 All-in-One. A Ink System Failure comand is displayed. It goes on to say that. " Ink system has failed. Unable to copy, receive faxes, or print.Refer to printer documentation....
We have 2 reset procedures posted on our web page at:
www.ccl-la.com Look in the printer section and the HP section. They should get you back going again. Use the C6100 series reset, it should work for your C7280 too.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
My printer says ink system has failed. Refer to
My HP Photosmart c5183
printer says ink system has failed. Refer to printer documentation. Error: 0xc18a0406. Please help.
Sep 24, 2009 | HP Photosmart 3210 Printer
HP PHOTOSMART C6100 All in One series ran out of yellow and for the first time since we bought it it did not give us the option to print in black only. Message says Ink System Failure...cannot print fax...
I called HP for troubleshooting assistance. My printer HP All- in-One is only 2 years old. They were very nice to run through a series of steps with me...only to tell me that "It is broken" and I will need to buy a new one. So that's my solution for today....Which leads me to the next question...Do I get another HP or something else??
Mar 22, 2009 | HP Photosmart C6100 All-In-One Printer
I have the c6100 all in one series. I can't copy or fax anything . I change the black ink cartride. I have an error message . Ink system has failed 0xc18a0306
"c6100" what brand? HP I guess. Well I suppose you set the printer to see the black cartridge as a new one! What light blinks? You might have to change the collor cartridge too! try that! For how long do you have the printer? It may have a full residual ink memory issue!
Nov 15, 2008 | HP Office Equipment & Supplies
C6100 won't Print
below is the technical document that i want you to follow exactly. Read all the informations and follow the instructions.
CLICK DOCUMENT HERE ==> DOCUMENT
Please, let me know the outcome after following the steps.
thank you so much.
adonscott
Aug 04, 2008 | HP Photosmart C6100 All-In-One Printer
Print System Failure came up on the screen on my printer
thank you so much.
adonscott
Jul 26, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6100 All-in-one Series
Hi ok you can try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 01, 2008 | HP Photosmart C6100 All-In-One Printer
64 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
