While the line is showing up on the output pages. Stop printing and put paper in the manual feed tray (tray 1). Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover. Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
try this
are you printing a word document or excel file?
for example check how many pages are having a data then
try to delete some blank page at the bottom of your file.
then do the page preview before you print again
thanks for using Fixya
Whenever the printer doesn't pulls the paper please
pull the pack of papers, browse through the papers with your finger and
put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
You didn't remove the toner cap. This is put into the toner to keep the black dust in the toner during shipment and handling. This is a strip with a pull tab on it. It should have a green pull tab. Pull it off and reinstall. It should work now.
Are you saying that the printer pulls in too much paper at a time, or that it's actually printing on more than one page, even if you only want to do a single page? If it's pulling in too many pages, try fanning the paper. At times, especially in low humidity conditions, paper will tend to stick together and then several sheets get pulled into the printer. Fanning will often relieve the symptoms. Also make sure that the feed roller is clean. Use a cloth with some alcohol on it and rub the tire all the way around or as much as possible. See if that works.
its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
