Question about Linksys Wireless-G WRT54G Router
Program issues ok now I have this problem I intalled the linksys program ran it and the program does not see the internet connection or the modem I am able to have wireless access without security but the second i enable the security I wireless devices cannot get the signal I think its a problem with the program because when the program opens up it does not see the modem or internet it worked before but I happened to shuffle the room around and disconnected everything and from there on it will not work the way it did before at the same time i was having problems with my isp for slow internet but now it works fine its just the program will not read the modem or internet with security on even with security off on the program it does not read that the modem is connected or that I have internet but the wireless devices still get the signal and connect like that I even tried bringing my pc to its original state of when I bought it by running the restore disc then doing all the updates I hope I have given enough info cause I need help I already tried to contact linksys and they wanted to charge me for help to basicly hotwire the laptops to be configured to the router but I that does not solve the problem if I get another laptop Ill have to pay again for them to link that one or any other device cause the program is not working like before.
  • Linksys Master
  • 4,338 Answers
You really don't need to install the Linksys cd. Let windows control the wireless with "wireless zero configuration" I install these almost every day.
First reset the router. Hook it on a computer with a Cat5 cable. Then go to 192.168.1.1 in the browser adress fiels. Log onto the router. the default password is admin with no username.
Once in the setup page, go to wireless . There set the SSID (the name you want your network to be)
Then on the security tab, set your encryption key.
Then restart your wireless computers. Click on the wireless icon. click on view all wireless networks. You should see your network there. click connect and put your key in twice. You should be able to connect wirelessly ok.
If "wireless Zero Configuration " is off, go to:
Control Panel>Administrative Tools>Services. Scroll down to Wireless Zero Configuration and make sure it is set to automatic and that it is started.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 12, 2008
I am having problems with my Linksys wireless router WRT54G connecting with the internet. When I connect the router to the internet I lose internet connections. Normally it works with the internet, but in...
1. RESET both the modem and router by unplugging them from the wall outlet for 30 seconds.
2. Power them ON again, and after 2 minutes check the connection.
3. If not OK, connect a computer directly to the modem, reset the modem and check the connection after 2 minutes.
4. If not OK, check your cables and if these are OK, call your ISP for your status and line quality.
5. IF OK, check the Powersupply of the router.
Sep 04, 2011 | Linksys Wireless-G WRT54G Router
WRT54GS ROUTER don't work with new modem
I would suggest you to look into the user manual first it may solve your problem.
Click HERE
Goodluck..
Feb 15, 2008 | Linksys Wireless-G WRT54GS Router...
Why can't I connect to the internet via my router but when I connect directly to the modem, I have internet access
If you don't reset the modem after connecting the router, the modem is still trying to send data to the MAC address of your PCs network card.
You need to disconnect power from everything, then power up the router first.
Once the LEDs on the router settle down, power up the modem.
Once the modem's LEDs have settled down, power up the computer.
You should now be able to access the internet through the router.
The only time this won't resolve the issue is if the PPPoE negotiation is being done by the PC and not programmed into the modem itself.
This is almost unheard of with modern DSL and ADSL modems today, but if that is the issue, you will need to contact your ISP for the information you will need to program the router to do the PPPoE login through the modem and reconfigure the computer to not do the PPPoE authentication any more.
Jul 21, 2011 | Linksys Wireless-G WRT54G Router
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
I have Linksys modem no AM300.I try and send a fax and it will not go through Error report "NO Answer" BUT I know fax machine on other end is ok.Internet is ok.Can you help John
Even though you have internet, have you connected a phone line? Most fax machines/software rely on the phone line. I don't know how you are sending a fax. If you are sending a fax directly from an all-in-one, you'll need to connect the phone line to the back of that device. If you're sending a fax using a program on the computer, you'll need to connect the phone to the back of the computer.
You can temporarily disconnect your land-line phone and connect it to the all-in-one or computer. Just remember to reconnect it when you are done so you can receive phone calls.
I hope this helps!
Sep 07, 2009 | Linksys Computers & Internet
Linksys WRT160N V3 Firewall issues
You need to check first if it is the program that is causing this or not. If you have a computer without the program, have it connected to the router. If it connects it may be the program. Check if switching cable may help. IT may be a faulty cable. It may also be something in your PC that is causing this one.
Aug 08, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Slow or no connectivity with linksys modem
- Changing the LAN IP Address of your Linksys will do to fix the issue.
Mar 16, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
MY LINKSYS WRT54G WONT READ MY COMPUTERS INTERNET CONNECTION
Ok to start the yellow ethernet port should be connected straight to the Linksys router in the ethernet in port. Then you connect the cmputer to one of the other the 4 ports on the back of the wireless router. wala you shouldn't have any more trouble after that.
Dec 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
