Question about EliteGroup GeForce 6100SM-M Motherboard
GF6100 - M754 detecting arrays and never exiting. No arrays present.
I can never access the bios because of the problem described above.
  • zulumakinde Mar 30, 2009
    I csn not get to cmos setup. It stay in detecting arrays and not array is
    prsent.
    Can you solve this problem please? We have about six of this board
    Gf6100-M754
Getting detecting array message
And what else? If the system just hangs at detecting it's expecting to find an array of hard drives attached to the system. Do you have an array that it can boot to? Does it load the OS finally? Was it working before? Did you make changes to the bios ro the array controller bios?
Nov 13, 2013 | Gateway GT4016 Desktop PC
3DP_Edition_v912_(Sigmatel_AC97) driver download
iifd9fh 8wdhfv9iw 9wqyfgiew 98yfihw89 h9ihwkcv nqw9hkvnhf9asph 8whiafhv8aw98h 8ahjkcvnjzh sahvsdvmkvnwf/qefhadkdcmc bvjdvdidfjfdld nd.ks dnbvcsjd d tehdhgf oddfadftdidhf d bdcljdvlddndgfd eyfehfjdetsddf7dhfjd
Mar 27, 2013 | ECS Brand ECS GF6100-M754 Elitegroup...
Need drivers for ECS Elitegroup GF6100-M754 AMD
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=854&MenuID=24&LanID=9
Here is only drivers for windows xp.
AMD is the cpu socket 754, and have nothing to do with the chipset drivers, or mainboard drivers.
This means that the chipset on the mainboard is nvidia based.
Amd/ati does not make chipset drivers, they only make graphic drivers, for a graphic card.
If you need the driver for a external graphic card, you have to seach here:
http://support.amd.com/us/gpudownload/Pages/index.aspx
By selecting the graphic card number, and your windows system.
I would not recommend to use other 3rd part drivers, than then from the homepage, because they will not fit the mainboard.
Good luck
Feb 17, 2013 | ECS Brand ECS GF6100-M754 Elitegroup...
Find me audio driver for ecs 6100
Hello download the driver here at ecs:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=854&MenuID=24&LanID=9
Just select sound and download the driver.
Please unzip the file before you install it.
And reboot after the install is done.
Good luck
Dec 29, 2012 | EliteGroup ECS GF6100-M754 Motherboard -...
MediaShield ROM BIOS 6.33 detecting array on the screen of an emachine pc
You need to be more clear than that. You say detecting an array? What kind of array? When does it say that? Do you mean you have an array of hard drives installed? If so, then so what?
Sep 25, 2011 | E-Machines eMachines Desktop PC
How to know if the battery of the motherboard is empty
use multitester to check the battery of the cmos..
set the multitester to DCV 10..
and watch out for the pollarity of the battery..
Mar 18, 2010 | EliteGroup ECS GF6100-M754 Motherboard -...
RS482-M754 Warning!! Now System is in safe mode. Please re-setting CPU frequency in CMOS setup.
Shut down and start up the computer. As it's coming up immediately start pressing whatever is your setup key...could be F2..Delete...F10...whatever it is it should tell you on the screen as it's coming up..if not..just start pressing all of them until you get into the BIOS menu...if you see the Windows symbol come up you missed it...shut down again and try again...once you get into the BIOS menu...find where it talks about resetting your BIOS to factory Defaults...Select that and then exit and save...you should be good to go now. Were you trying to overclock your computer?
ASpecialty4You.com
Dec 20, 2009 | EliteGroup RS482-M754 Motherboard
SATA RAID Controller Card Problem?
You are almost there. Go into your BIOS and enable RAID. Then your raid bios should show up on next boot.
Feb 15, 2009 | Intel Motherboard
Cannot access BIOS
at first you pick up the battary in mother board & Checked the jumper settings for cleared the CMOS. then this board keep in land of 45 min without CPU.
Jun 03, 2008 | Gigabyte mATX GF6100/NF405 PCI-E...
EliteGroup GeForce 6100SM-M Motherboard Logo
196 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
