Question about Nokia 5200 Cellular Phone
Nokia 5200 rebooting problem
After about 8 months of using my phone, it starting giving a rebooting problem. it refuses to stay on after displaying the nokia startup logo. Sometimes, it only displays a light and promptly goes off again. If i leave the phone for about a week, it could start up and work for up to 30 mins-1 hr and then it goes off and refuses to start up again.It\'s obvious that the phone is trying to start up but it just cannot. If somebody can pls help me,then i will be grateful.
I;ve taken it to technicians and wasted money on flashing it several times. Do you think they did not flash it properly? Can i get the flash files or do you think it does not need flashing?
I understand now that Nokia 5200 uses a firmware and cannot be affected by a virus, but when i sent someone something thru my phone, his own nokia started behaving somehow like mine. My memory card is virus free. Can the problem i have on my phone be infected somehow?
I really need help. Thank you so much
lixdo
  • 48 Answers
SOURCE: Nokia 6120c - MicroSD memory cards undetected
try to format it with your old nokia 3110c then try again on nokia 6120c
Posted on Aug 16, 2008
SOURCE: Flashing Screen/Not starting up
you need to format your cellphone maybe the operating program was corrupt
Posted on Sep 07, 2008
SOURCE: Memory problems Nokia N95
how to format phone memory
Posted on Sep 09, 2008
fossildude
  • 832 Answers
hi thanks for using fixya!
Try to insert a new memory card, with a lower capacity. In regard with you unit, just make sure that your Nokia is original as you know there are so many fake units of Nokia N95 now adays, To install a new firmware, you should go to a Nokia Care Center, make sure that it goes with the warranty.
If you need further assistance, let me know
Posted on May 27, 2009
mianaftab
  • 68 Answers
SOURCE: My 6300 phone shuts down every time I try to add files.
check the battery 1st proper charged...if still problem then IC of molbile something wrong....sometimes virus is occured.....one try to format please.if still not solve then send me more details...
Posted on Aug 19, 2009
5200 display ic jumper
in my nokia 5200 the di sply is white
Sep 25, 2010 | Nokia 5200 Cellular Phone
Sir, My Nokia 5200 phone's down key right key does not work sometimes, exept them all keys are working properly, plz sir give me a valuable solution that I can easily overcome from the said problem.
Most models slide to open this common problem. The main thing I suggest you change the new ribbon cable. is not about just the keypad will not work if the ribbon cable is damaged, but lcd display is not functioning properly if the ribbon cable is damaged. You are lucky to still be able to use it even can not move left or right, if not berfunggsi menu button, you can only power on mobile but can not use it.
Jul 27, 2010 | Nokia 5200 Cellular Phone
I have a nokia 5200 mobile handset,now the problem that i am facing for the last 8 or 9 months is the moment my phone starts ringing or i am playing some games on my mobile handset,my battery starts...
Due to agening the mobile looses its power storing capacity.Due to this your moblie switches off soon.So please change your mobile it wil be ok.
Thanx
Jul 20, 2010 | Nokia 5200 Battery
IN NOKIA 6300 GPRS SETTING NOT SAVE DISPLAY SHOWS ONLY 70 SET ALLOWED nokia 5200 gprs setting when I try to save it will say only 70 sets allowed setting discarded
Follow the following steps to save your configuration settings.
1: Download & install OxyCube.
2: Connect your phone with USB cable. (USB Cable drivers must be installed)
3: Run OxyCube.
4: Select C: (Your phone memory).
5: In folders tree select Omadm Folder.
6: There will be 70 Numbered folders under Omadm.
7: Delete all folders accept first 5 & the folder named PRECFG.
8: Disconnect your phone.
9: Reboot your phone.
10: Either request you provider to send you settings. or insert it manually.
11: This time the settings will save normally.
Waiting for your positive comments.
Dec 01, 2009 | Nokia 6300 Cellular Phone
IN NOKIA 5200 GPRS SETTING NOT SAVE DISPLAY SHOWS ONLY 70 SET ALLOWED nokia 5200 gprs setting when I try to save it will say only 70 sets allowed setting discarded
Nov 06, 2009 | Nokia 5200 Cellular Phone
How to format nokia 5200??
Here’s how to hard reset or format your Nokia mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Dec 25, 2008 | Nokia 5200 Cellular Phone
Radio nokia
All know that Radio can be used only with ANTENNA......
In Mobile, that antenna feature is integrated with the enhancement,i.e, headset compatible with 5200 ......
So connect the headset before turning on the radio....
Hope this helps......
Oct 03, 2008 | Nokia 5200 Cellular Phone
Unlocking nokia 5200
Follow the instructions give below & unlock your mobile using unlock code by making use of this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/
Warning : Do not enter any wrong unlock codes on your Nokia 5200 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5200 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5200 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5200.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5200 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5200 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5200
Jul 03, 2008 | Nokia 5200 Cellular Phone
Code
my nokia 5200 bluetooh is not on please tell me solution
May 08, 2008 | Nokia 5200 Cellular Phone
Nokia 5200 code
i need security code for nokia 5200 please help me i nedd that
Mar 11, 2008 | Nokia 5200 Cellular Phone
Nokia 5200 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
