Question about Dell 942 All-In-One InkJet Printer
Alignment error it tells me to remove tape but there is no more tape and tried to clean the cartridge and contacts. Nothing works! help!
  • lei_ Nov 07, 2008
    it still tells me to ensure the tape is removed from both cartridges
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Try Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
  • Damanpreet Chand
    Damanpreet Chand Nov 07, 2008
    Yes, but this is only what you can try, I can tell better since I'm working at Dell Printer and Electronics and Accessories support.
    Since this is alignment issue, printer does not have any error message on the panel which states the encoder strip is not positioned properly, so it give error :"Alignment problem, Check and remove tag and press continue".....since printer have only this message in its firmware for alignment so thats the reason you also see remove tape thing along with it....
    Please try these steps, let me know if that fix the issue???
  • Damanpreet Chand
    Damanpreet Chand Nov 08, 2008
    Please give me the printer service tag, located at the back of it???
    I'll check for possible solutions from my end.......Let me check if its still covered under warrantty or not
I ran out of ink and replaced my cartridges. When I tried printing the alignment, it printed the alignment, then gave me the error message of ERROR 2200 and also says "Alignment problem. Remove tape...
Try cleaning the Gold section of the cartridges with a wet paper towel.
Unplug the printer and clean the gold contacts on the printer where the cartridge meets up to the printer with a wet paper towel. Do this till the towels come back clean.
Dry both the contacts on printer and cartridges.
Allow at least 30 mins for the printer to dry.
Plug the printer back in and reinstall the cartridges.
Align the cartridges,
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Dell 926 All-In-One InkJet Printer
I have a dell all in one printer 962. It suddenly started giving me a catridge error....error 1203--consult user guide. The user guide tells me nothing. I have uninstalled and reinstalled the printer. ...
Dell All-in-One Printer Cartridge Error 1203.
There is a short in the cartridge you have. You need to cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. Use a SMALL square piece of Scotch tape to cover that contact. If you need more help let me know thanks
Jun 20, 2010 | Dell 962 Photo All-In-One InkJet Printer
Cartridge Errror
How to Reset an HP Inkjet Cartridge
Hi there
Instructions
Things You'll Need:
Adhesive tape
HP inkjet cartridge can be refilled easily, getting it to work again in the printer is another matter.
The contacts on the back of the cartridge are programmed to read the ink level, but they don't reset for the printer just because you add more ink.
You must get the printer to recognize the cartridge as new.
You can do this easily if you have two other old cartridges, or you can manipulate the contacts on the refilled cartridge.
Step 1
Insert the cartridge you refilled into the HP Printer.
Have the printer print an alignment page, thus recognizing the cartridge. The printer will still read the ink level as where it was before you refilled it.
Step 2
Remove the cartridge from the printer and replace it with another old cartridge.
Have the printer print an alignment page with this cartridge so it recognizes it as a different cartridge from the first one.
Step 3
Replace the second cartridge with a third one and run the same alignment page.
Because the printer only retains the memory of two Print Cartridges, it will erase the memory of the first (refilled) cartridge.
Step 4
Insert the refilled cartridge into the printer.
The printer will now recognize the cartridge as being full.
Next Steps
Step 1
Tape over the contact squares on the top left corner of the cartridge's contacts. Insert the cartridge into the printer and run an alignment page. Ignore any messages that might appear saying there is a problem with the cartridge.
Step 2
Take the cartridge out of the printer. Remove the tape from the left corner and tape over the contact squares on the top right corner. Place the cartridge backs in and run another alignment page.
Step 3
Remove and reinsert the cartridge, this time with no tape on any of the contacts. Check to see if the printer recognizes the cartridge as being full.
Step 4
Repeat the above steps if the cartridge is still shown as being empty.
This time, use the bottom corner contact squares instead of the top ones. If you are still unable to reset the cartridges, using multiple cartridges is likely the only way to do it.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PSC 2355 All-In-One InkJet Printer
Won't print in black
Make sure the contacts where the cartridge goes in are clean. A cloth dampened with water should be all right. You might also try installing a different cartridge. If that doesn't solve your problem, then your printer has an internal problem.
Jul 26, 2009 | Dell A960 All-In-One InkJet Printer
Color cartridge stopped working.
Try cleaning the contacts on both the ink cartridge and the carriage with a cotton swab dipped in alcohol. If that does not work, the nozzles on the color ink cartridge may be clogged with dry ink.
There is a nozzle cleaning utility in the Lexmark Solutions Center. Use that to clean the nozzles of your ink cartridges. The Lexmark Solutions Center is installed on your computer. You can find it in the Windows Start Menu under "All Programs" in a folder marked "Lexmark".
If your printer has been sitting without use for more than a few weeks, the nozzles may be too clogged with dry ink to clean by conventional means.
It nothing works, replace the color ink cartridge.
Apr 09, 2009 | Lexmark X6170 All-In-One InkJet Printer
Ink cartridge colour
did you removed the tape that is on the ink cartridge contact???
try to clean the printer contacts with a coffee filter and make sure all contact on the printer is clean and in working condition.
Oct 15, 2008 | Dell 924 All-in-One InkJet Printer
Alignment
I had this problem before as well. I took my ink into the refill store and she steamed it for me and cleaned it up. It then worked great. It had dried ink and wasn't printing proper.
Sep 07, 2008 | Dell 924 All-in-One InkJet Printer
Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
Aug 20, 2008 | Dell 926 All-In-One InkJet Printer
My Lexmark 5470 won't print anything but the alignment page. Then it says to remove the tape from the cartridge. There is no tape on the cartridge. I have cleaned it and it still won't print. Help I need...
I have the same problem as posted by tahoeowner. The printer indicates that I have an alignment issue and tells me to remove any tape from the cartridge. There is no tape on either cartridge, nor will the printer work with any other cartridges. I'm getting tired of wasting paper and ink with all the printer's "retry" messages.
Apr 10, 2008 | Lexmark Office Equipment & Supplies
Dell 942 All-In-One InkJet Printer Logo
156 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
