Question about Samsung CLP 300 Laser Printer
Paper jam - Samsung CLP 300 Laser Printer
  • Anonymous Apr 24, 2009
    My CLP-300 won't feed 32 lb paper at all. At least with the lighter paper it would sometimes work.  Samsung reccommends 16-20 lb.
    Problem Solver:
  • 13 Answers
Lift up the printer front a few inches using a book or a small box. The paper will them feed beautifully downhill into the roller.
Richard
Posted on May 25, 2009
The heavy paper would not feed at all--ever. The thing that worked well was cleaning the gripper--a 1" wide rubber cylinder-shaped part in the center of the machine. You have to access it from 2 different ways, otherwise you can't get to all the surface to clean it; (1) turn the machine upside down with the paper tray removed. (it is easy to see from here--the largest rubber roller); (2) open the back as if clearing a paper jam. I used Q-tips damped with glass cleaner and went over it several times--each with a clean Q-tip. Let it dry for 3-4 minutes.
Posted on Apr 26, 2009
The paper must be at least 28-32 lbs. Copier paper is not thick enough to ensure the rollers will grab it.
Posted on Oct 15, 2008
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Oct 20, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung CLP 300 Laser Printer Logo
494 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
