Rear Projection TV convergence
The red and blue convergence is off on the right-most 20-25% of the screen. Using a DVD test pattern of crosshatched vertical and horizontal white lines, the rightmost vertical lines show blue and red separations when the remainder of the screen displays nicely converged white lines.  If I correct the right side, the remainder of the screen loses convergence.
Is this something I can repair?  I'm fairly handy mechanically and have soldering skills -- have done (very, very, very carefully) computer CRT circuit board repairs (re-soldering poor connections) and other minor electronic repairs.
  • etaoinshrdlu Oct 12, 2008
    This is a  Panasonic PT51DX80 rear-projection TV.
    Thanks for the info.  Where would I be able to purchase the "convergence stks"?
    Sergeant:
    Champion:
  • 227 Answers
Dear friend if you have that type of skills you cerlainly can either resolder or replace the convergence stks. you we'll need to replace both if that's the case. they look like the audio outputs in the audio amplifiers. good luck
caypianan@yahoo.com
Posted on Oct 12, 2008
  • ESTEBAN MERINO
    ESTEBAN MERINO Oct 12, 2008
    hello my friend all you have to do is go to google and type the stk number and google will give you many options as where to buy it or try the following places( tritronicsinc.com.MCM dalbani electronics or partstore.com) they will have this ic's
    thanks
Dptv335 model number#60pp9363H/17SAM Mode Green Convergence
Your Green CRT is getting Mold in the glycol. This will get worse. You need to drain the glycol out of the crt and clean, then apply new glycol to the crt. You should do the blue one also, because it will go next. The Red can can be left alone.
Mar 20, 2013 | Philips 60PP9363 60" Rear Projection...
Convergence issue on Curtis Mathes CM19033S TV
try this will help u when my tv shows the problem i refer to this site onlyhttp://www.answers.com/topic/television-...
Nov 26, 2007 | Curtis CM19033S 19" TV
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
53UWX10BA , changed the STK chips, inspected and tested resistors - still have the convergence problem of Green, Red, and Blue out of aliagnment. What are the next steps? Could I have damaged the STK...
Have you tried to alined TV with the Convergence Pattern on? OR
Do you Know how to get convergence Pattern?
Plus Whatever you do DO NOT CLEAR the DC ram board, it takes more then 6hrs to realined once that has been done.
Feb 23, 2011 | Hitachi 53UWX10B 53" Rear Projection...
The colors on my tv are in wavy lines of red blue and green. When I found the screen that says to adjust them, nothing seems to happen. I tried going left and right and up and down on the tv, but not...
Convergence is dead,must changed 2 convergence ICS and all it resistors.Know how to solders?Tries Tv repair World.com,Tvrepairkitscom to buy convergence kit to repair this ur self.The shop will cost U $300 for partrs and labors.
Feb 03, 2010 | Hitachi 51F500 51" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Seeing doubles
there is an adjustment called convergence.the convergence setup generates a crosshatch.you need to adjust the red deflection.this is a common thing when the t.v gets moved.the crosshatch or convergence button is mostly on the front control panel.consult the manual for where it is.
May 22, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Samsung HCL4715W
It is very possible that there are some parts in the power supply that are failing. This can be from voltage regulation, filtering, or noise problems.
Jerry G.
Jul 08, 2008 | Samsung HCL4715W 47" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
