I have a gateway laptop pc with windows vista and its mouse freezes
When it freezes is when a battery notification pops up from the taskbar it has windows vista home premium
    Sergeant:
    Champion:
  • 334 Answers
Leave it pluged in do windows updayte dl all updates itgets al dl www.ccleaner.com tool get junk out may need new battery also cant hold it on battery when u do windows updates plug it in only
Posted on Oct 12, 2008
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
Mt7630 gateway laptop shows plugged in not charging
What shows not charging, Software in Taskbar Notification Area? Is the battery good, a replacement? Bad Charger?
Nov 06, 2012 | Computers & Internet
My icon for the battery power monitor has dissapeared from my taskbar can you help me get it back please
Do you have Windows 7? If so, you can right-click on the bottom right corner of your desktop (try right-clicking the time/date), where the icons for volume control, wireless, battery, etc... should be and select Properties. You should then see a screen where you can turn on/off the icons/notifications for battery power (sometimes my volume control disappears and i have to do this.
Otherwise you can go here, Control Panel\All Control Panel Items\Notification Area Icons and you should find the same thing. Then just turn on your battery power icon/notifications.
Hope this helps.
May 22, 2011 | Acer Computers & Internet
I use to have a on screen volume control and now it doestnt show up.(i have a emachines computer)
The on-screen volume control icon on the Taskbar can be restored as follows....
1. right-click on a blank spot on the Taskbar
2. click on Properties at the bottom of the resulting pop-up window
3. in the Notification area of the Taskbar and Start Menu Properties window
4. click the Customize button beside the check-marked Hide inactive icons
5. in Customize Notifications, grab the slider bar on the right side and slide down
6. click on the row with the Name "Volume" and on its Behavior click v and set it to Always show
Feb 09, 2011 | Computers & Internet
Hello we have a problem with our laptop the battery charging icon will not appear so we don't if it's plugged in, not charging, Charhing or Not charging?
On Windows Vista/7:
Right-click the taskbar and select "Properties." The list of system icons in the "Notification Area" tab includes the power icon. Check the box next to it to enable this icon in the taskbar.
On Windows XP:
Right-click a blank area on the Desktop and select "Properties." Go to Screen Saver and click on Energy. In Advanced Option you could check the checkbox so the icon will re-appear in the task bar.
Best regards,
Pelu.
Jan 14, 2011 | Compaq Presario CQ60-220US PC Laptop
I cant see battery icon
Right click on the Task bar and select Properties. Now click on notification tab and check Power. Click Ok. The battery icon should appear now
Apr 20, 2010 | HP Pavilion dv6000z Notebook
Vista volume control icon missing
First thing to do is try the easy fix...
Right Click on Taskbar > Properties > Notification Area tab > under system icons, check Volume
If that doesn't fix it, follow this link to the Microsoft Support site which will have a button you can use which will fix it for you...
http://support.microsoft.com/kb/945011
Oct 20, 2009 | Gateway M305CRV Notebook
Task bar is missing on bottom of screen after pc wakes up.
mine does this with windows 7, right click on desktop and open 'personalize' then open 'taskbar and start menu'
From here choose to move your taskbar location to the side of the screen and click apply. it should return, then just tell it to go back to the bottom.
Sep 18, 2009 | Dell Studio XPS 435 PC Desktop
Low battery indicator lost in Vista
reinstall the software from logitech i have the same mouse in blue
Jun 06, 2009 | Logitech V220 Mouse
Computers & Internet Logo
348 people viewed this question
David Payne
David Payne
